[Z06] Do ls1 headers fit ls6?
Old Dec 17, 2008 | 11:50 PM
prscttsrvcs's Avatar
prscttsrvcs
Default Do ls1 headers fit ls6?
Will the ls1 headers fit and clear everything on a ls6?
Old Dec 18, 2008 | 01:02 AM
striper's Avatar
striper
Yes, there are no physical differences of the motors externally nor the engine compartment. The LS6 just has more ponies to start.
Old Dec 18, 2008 | 05:08 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Old Dec 18, 2008 | 07:29 AM
AU N EGL's Avatar
AU N EGL
does not the LS1 heads( 241) have 4 head bolts and the LS6 heads( 243) have 6 head bolts?
Old Dec 18, 2008 | 11:56 AM
RedLS1GTO's Avatar
RedLS1GTO
Is that really the case? I have never actually looked, but I thought you could bolt LS6 heads right on to an LS1. I know a ton of the '04 GTO guys were running LS6 heads.
Old Dec 18, 2008 | 12:07 PM
hotwheels57's Avatar
hotwheels57
And aren't the air pump valves different from '97 to '99, 2000, and '01 to '04? That might require some consideration and modification...
Old Dec 18, 2008 | 02:40 PM
prscttsrvcs
Reason why im asking is for 500 bucks on ebay you can buy a turbo kit for ls1 that consists of headers and all the piping to run single turbo set up. I would still need to purchase a turbo, wastegate, I/C and piping, but for 500 bucks for the hot parts, its not bad.
Want a link?
Old Dec 18, 2008 | 02:47 PM
prscttsrvcs
http://cgi.ebay.com/ebaymotors/Turbo...spagenameZWDVW
Old Dec 18, 2008 | 07:03 PM
prscttsrvcs
anyone? My gf is willing to oay for 300 of this for xmas, so why not? Does anything think this will fit the vette?
Old Dec 18, 2008 | 07:09 PM
zenohsixxx's Avatar
zenohsixxx
Thats for an fbody, will not what so ever on a vette, only the headers, maybe. The rest in made for the fbody.
Old Dec 20, 2008 | 03:13 AM
EFNFAST's Avatar
EFNFAST
$500 e-bay turbo kit; there''s absolutely no way this can turn out bad....no way......
Old Dec 20, 2008 | 07:40 AM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Other than the World, ERL, and LSX all LS type stock GM block and heads are 4 bolt.
No that kit will not work for a Corvette.
Old Dec 20, 2008 | 09:31 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Isn't the original question about headers, not heads?
Old Dec 20, 2008 | 07:06 PM
Z06PSI's Avatar
Z06PSI
O.K. then all headers are also 6 bolts for all types then. I was answering the head bolt question.
To Do ls1 headers fit ls6?
