[Z06] Dic code??
Old Dec 19, 2008 | 05:42 PM
JustinZook's Avatar
JustinZook
Default Dic code??
Check engine just poped up and the DIC COde was P0430 TWC System Low Efficiency Bank 2 .... any ideas what this one means?? i havnt got any work done on it. ?? any ideas
Old Dec 19, 2008 | 06:22 PM
JustinZook's Avatar
JustinZook
bad C02 sensor?
Old Dec 19, 2008 | 06:25 PM
hotwheels57's Avatar
hotwheels57
Try an internet search using "P0430 TWC System Low Efficiency Bank 2" as keywords...
You should come up with a lot of information to lead you in the right direction...
Old Dec 20, 2008 | 09:31 AM
lbarnard's Avatar
lbarnard
Catalyst System Efficiency Below Threshold (Bank 2)
What does that mean?Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
SymptomsYou will likely not notice any drivability problems, although there may be symptoms such as a rough/hard idle when cold.
CausesA code P0430 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
There is an exhaust leak
Possible SolutionsFirst, inspect for exhaust leaks.
Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into
Old Dec 20, 2008 | 04:36 PM
JustinZook's Avatar
JustinZook
thanks for your help.... beautiful boxer by the way
Old Dec 21, 2008 | 08:04 AM
lbarnard's Avatar
lbarnard
I had my O2 sensors go out if they are not covered shop around online you can save $$$! thanks for the comment on the boxer he is one of two we rescued this year after our other passed away
Old Dec 21, 2008 | 09:27 AM
gasboy's Avatar
gasboy
on an unmodified car,the feds force the mfgs.to warranty catalytic converters for eight years or 80,000 miles.
To Dic code??
