Auto Climate Control
Old Dec 19, 2008 | 06:11 PM
brzman's Avatar
brzman
Default Auto Climate Control
I cannot set the temp on my heat or A/C on the driver side **** ?
good thing i can grap some heat out of the passenger side.....
anyone else have this problem ?
thanks
Old Dec 19, 2008 | 06:12 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Talk to SilverC54me (Gary)
He's done a DIY write-up about about resoldering the connections to fix that.
Old Dec 19, 2008 | 06:23 PM
mike10626's Avatar
mike10626
Can you shut it off or change the temp.?
Old Dec 19, 2008 | 06:39 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
If it's just the Driver's ****/Pot I have a spare one, can you solder it in?
Old Dec 19, 2008 | 11:10 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
Check your codes... If it's blowing hot out of one side and cold out of the other, it's more than likely throwing 0441 or 0443 which is the actuators. Very common problem as I have recently discovered
Old Dec 20, 2008 | 01:10 AM
tstar's Avatar
tstar
Malfunctioning actuators will not affect the Driver's **** from adjusting the set cabin temp on the display... I'm assuming the Display's temp setting is not changing when the **** is rotated.
Tim
Old Dec 20, 2008 | 04:22 AM
DeeGee's Avatar
DeeGee
thanks
What codes are being set?
To Auto Climate Control
