are you having trouble with your doors or windows? It sounds to me like you're losing power to both door control modules, which in some cases can be as simple as a short or broken wire in the cable bundles going into the door
Those are codes set by voltage issues with the left and right hand door control modules.
Interesting that the fault is with both the LDCM and the RDCM which makes me think the problem is not at the door modules but, more likely, upstream.
Had it been left or right individually I'd have suggested checking the wiring in the rubber gaiters in the door hinge area for chafing. Even so, it would still be worth a quick look.
The troubleshooting guide suggests checking connectors for poor fit/corrosion. Take a look at the door module connectors at the instrument panel electrical center. Has it got wet down there at any stage?
I had those and a few others (both doors) when the OEM battery was going out. After the new battery was installed, I cleared everything and no more problems.
