REAR WHEEL STUD REPLACEMENT 2003 zo6
Old Dec 23, 2008 | 08:27 PM
yellowLPEZO6's Avatar
yellowLPEZO6
Default REAR WHEEL STUD REPLACEMENT 2003 zo6
If you have replaced rear wheel studs on a c5 corvette please help.
I need to replace the OEM rear wheel studs with ARP 2 1/2 in. length in order to use a 1/2 in. spacer on my 2003 ZO6.
Can you replace them without a complete disassembly ?
Thanks in advance
yellow lpe zo6
Old Dec 23, 2008 | 10:53 PM
flash of red's Avatar
flash of red
Yes, you will need to drill a hole in the metal backing plate for the emergency brake.This will allow you to slip in the new bolts as you rotate the hub. I've done it twice. It is a certain spot on the plate you need to carefully drill the hole then fill it with a rubber grommet when done. Do a search in the tech section. There used to be some threads with pictures.
