Difference between X and H Pipe
But the translator like this, translates literally, so the semantic isnt always correct, is like said:
El auto comienza a caminar cuando la luz se pone en verde
The car start to walk when the light put on green , instead of: The car starts to run when the sign turns green
But gives a close enough idea..
Thanks men, I know that the friendship by the same hobby, in this case the Vettes, is without countries but may be this guy can not live thinking that there are too much mexicans that can afore the same or better cars than him.
On the other way, if is just a joke, no problem for me.
Que disfrute de su Corvette.
Ed
Don't turn into the usual "group of angry geezers" deal where I'm attacked by bitter old men for sharing what OTHERS think.
Ed
A benefit of an X-pipe, over an H-pipe, in addition to a greater scavenging effect, is a "smoothing" of the exhaust tone and a reduction in the "popping" sound, that seems to come with many aftermarket exhausts, and some people don't like. With just an H-pipe, each exhaust pulse travels down it's exhaust pipe until it comes to the H-pipe. At that point, some of the pulse will cross over into the other exhaust pipe because of differential pressure (lower pressure on the non-firing side), creating the aforementioned scavenging effect. As some of the pulse is crossing over, and, therefore, taking a longer path out to the tailpipe, the result is basically non-synchronous pulses out the tail pipes, and one larger than the other.
With an X-pipe, both exhaust paths join. So now, when an exhaust pulse exits the X-pipe, a relatively equal amount of pulse is traveling down each exhaust pipe. The result is relatively equally sized, synchronous, exhaust pulses exiting the tailpipes, thereby "smoothing" the sound. This is in addition to a greater scavenging effect due to a larger pulse exiting the non-firing side tailpipe.
Ed
I have longtubes, no cats, h-pipe, and PRT's and it gets tons of compliments, sounds better than the Corsa or Borlas I've had.
