reduced power mode "NO SES" ?
Old Dec 29, 2008 | 10:36 PM
BLKY2KVETTE's Avatar
BLKY2KVETTE
4th Gear
Default reduced power mode "NO SES" ?
2000 VETTE LS1 auto/
car starts normally everytime. with scanner connected all systems are within normal range in "open loop" mode. the car warms up and goes into closed loop mode, maybe 4-8 minutes running, the coolant temp maxes the oil pressure hits 0 , the fuel gauge hits E , and the headlights go on. REDUCED POWER mode or limp home mode has engaged..but NO SES. NO CODES and the pcm triggers a loss of comunication with the scanner so i can't see what systems are being affected ...What Gives???? any help is greatly appreciated. thanks.
Old Dec 29, 2008 | 10:48 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
No help here, I'll bump it to the top for some more looks. Good luck, maybe a short somewhere?
Old Dec 29, 2008 | 11:16 PM
bencini231's Avatar
bencini231
Old Dec 29, 2008 | 11:24 PM
87SAM's Avatar
87SAM
Battery, alternator, battery droppings on PCM
Old Dec 30, 2008 | 02:40 AM
Bill Dearborn's Avatar
Bill Dearborn
The first problem you have is using a scanner. Unless you have a Tech 2 or equivalent scanner the scanner can only provide powertrain codes. Use the On Board Diagnostics displayed on the DIC so you can see codes from all the subsystems on the car (Push and hold the options button while pushing the fuel button 4 times). There are chassis codes that will cause a reduced engine power response.
Bill
Old Dec 30, 2008 | 10:05 PM
BLKY2KVETTE
4th Gear
i will check the onboard codes. also the window/door lock module took a dive and i read somewhere that it might have an effect. any thoughts?
To reduced power mode "NO SES" ?
