Headlight gear continues running
Old Dec 31, 2008 | 06:08 PM
nuklhd's Avatar
nuklhd
St. Jude Donor '09
Default Headlight gear continues running
Hello newcomer to this great forum and Corvettes. I just bought a 2001 convertible and I have a couple of small problems. The gear on my passenger side headlight continues to run for about 5 seconds after the headlight door closes, will I need to replace the gear or is there an adjustment I can make. Thanks in advance for any help.
Nuklhd
2001 Convertible
Old Dec 31, 2008 | 06:11 PM
fullforce1234's Avatar
fullforce1234
Mine is doing the same let's just wait and see what everyone else has to say.
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
welcome..
check out my first post here http://forums.corvetteforum.com/c5-t...with-pics.html
many other great tech tips in that thread as well...
*** Isee Rodney updated his page...here is the link to find what you need http://www.rodneydickman.com/retail_new.html
Old Dec 31, 2008 | 06:13 PM
pinballfanatic's Avatar
pinballfanatic
Your nylon gear for your headlight motor is chewed up....don't ask me how I know.......
Someone here on the forum should have the link to a gentleman that will supply you a kit with a BRASS GEAR....TOOK CARE OF MY PROBLEM.!!
Old Dec 31, 2008 | 06:19 PM
pewter99's Avatar
pewter99
yep
Old Dec 31, 2008 | 07:14 PM
bencini231's Avatar
bencini231
The gear is an easy DIY project, so do a search so you can find a write up with instructions. Good luck.
Old Dec 31, 2008 | 08:48 PM
nuklhd's Avatar
nuklhd
St. Jude Donor '09
Thanks for all the great feedback. I am gonig to order those new gears first thing in the morning. Thanks again.
Old Dec 31, 2008 | 11:05 PM
pewter99's Avatar
pewter99
Rodney ships fast...usually priority mail
Old Jan 1, 2009 | 12:00 AM
silverbullit99's Avatar
silverbullit99
Easy fix, just order some new brass gears much better than the nylon ones. Here's another how to link .. http://forums.corvetteforum.com/c5-g...orialized.html
Old Jan 1, 2009 | 12:44 AM
pewter99's Avatar
pewter99
BTW...order 2...if you do 1 the other one will go next week
Old Jan 1, 2009 | 02:58 AM
DeeGee's Avatar
DeeGee
Good advice
Of interest, I had a motor fail quite early on in my Verts life and it was replaced under warranty. In the meantime, I fitted the T85 (US T84) headlights which are much heavier so they put more strain on the motor. I ordered two brass gears ready to fit thinking it's only a question of time.
Hope you fix the problem easily
Old Jan 1, 2009 | 08:09 AM
Tom/99's Avatar
Tom/99
welcome..
Thanks!
To Headlight gear continues running
