[Z06] Window tint question
Old Jan 11, 2009 | 10:14 AM
tremor1's Avatar
tremor1
Default Window tint question
Just got my '02 Z06 2 weeks ago and want to tint the windows.Just wondering about the band of dots at the top of the back glass. Does the tint contour to these or will I see a clear spot at every dot? Where I live you pretty much need tinted windows in the summer. Thanks in advance.
Old Jan 11, 2009 | 10:57 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Mine has the clear dots around each dark dot.
Old Jan 11, 2009 | 11:26 AM
Wunderdawg's Avatar
Wunderdawg
First of all find someone who really knows what they are doing. The dots have to be sanded down, then have a strip of black vinal (sp) place over where the dots were. after that tint as usual.
If this is not done it will look like ****.
Later
Old Jan 11, 2009 | 12:03 PM
KING Z06's Avatar
KING Z06
When i first got my tints done the spots were visible but after about a month they went away and barely can be seen
Old Jan 11, 2009 | 12:11 PM
tremor1's Avatar
tremor1
Later
That makes sense. It will look like the black band around the back glass just a little wider at the top. Thanks!
Old Jan 11, 2009 | 09:43 PM
Over-torque's Avatar
Over-torque
Later
not to criticize the poster, but the dots do not have to be sanded down. the reason to sand the dots down is allow tint to stick. use the black vinyl and you do not have to do this. just press the vinyl into the dots really well and apply heat through the glass with a hairdryer/heat gun and you shouldn't even see any air pockets. if there are any bubbles, you can use a pin or razor blade to pierce the pocket and your finger to press out the air.
Old Jan 11, 2009 | 10:26 PM
corvette8189's Avatar
corvette8189
does anybody make a perfect black vinyl piece? if not, where would you get some black vinyl from and what would you use to make it stick?
Old Jan 11, 2009 | 10:38 PM
JGOAT's Avatar
JGOAT
most tint shops have vinyl and will even install it for you
To Window tint question
