[Z06] Opening the console lid
Old Jan 11, 2009 | 11:14 AM
sammm's Avatar
sammm
Default Opening the console lid
Sorry for the newbie question. Is the console lid supposed to open all the way up? When I pop it open, it only goes 1/2-3/4 of the way up. Is that normal? Thanks in advance!
Old Jan 11, 2009 | 11:24 AM
TheDingo's Avatar
TheDingo
Mine does the same thing.
Old Jan 11, 2009 | 11:26 AM
slvrzo6's Avatar
slvrzo6
Yes, It goes all the way up.. It's got a weird hinge. But it does go all the way up or vertical! You gotta pull up and a little over!
Old Jan 11, 2009 | 11:44 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Open it up a little then pull outward then it should open all the way up.
Old Jan 11, 2009 | 11:58 AM
hotwheels57's Avatar
hotwheels57
Apply a minute amount of lubricant on the hinges to make it open a little easier...
Old Jan 11, 2009 | 12:05 PM
sammm's Avatar
sammm
Thanks for the quick replies guys. I just hit the hinge with some silicone spray and it pops right open and up now.
Old Jan 11, 2009 | 12:06 PM
tremor1's Avatar
tremor1
It's like a doublejointed hinge. Open it a little then put your fingers under the lid on the hinge side and pull straight up as you continue to open with your other hand. Works for me. And remember the only dumb question is the one never asked. Good luck
Old Jan 11, 2009 | 01:11 PM
bencini231's Avatar
bencini231
Old Jan 11, 2009 | 01:49 PM
RSuperfreak3's Avatar
RSuperfreak3
Thought mine was broke the first time I tried it. Took me a few minutes to figure out the "weird hinge"...not sure why it just cant open like normal...
Old Jan 11, 2009 | 02:09 PM
tremor1's Avatar
tremor1
I think if it was a regular hinge the lid would hit the E brake handle when it is in the up position.
Old Jan 11, 2009 | 02:15 PM
RedLS1GTO's Avatar
RedLS1GTO
keep opening when it "stops" halfway. It'll pop open all the way to vertical.
Old Jan 11, 2009 | 02:19 PM
killain's Avatar
killain
Oldtimer
Mine has done the exact same thing since I bought it. I once asked about it at the dealership, They said that's how it works?
Old Jan 11, 2009 | 02:25 PM
sammm's Avatar
sammm
The silicone spray worked wonders on the hinge after I worked it in a bit. It now opens totally and easily without the extra tug towards the drivers side.
Old Jan 11, 2009 | 08:19 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
This makes it work well, still kind of fragile and not to be forced!
http://www.cau-llc.com/tips.htm#console
Old Jan 11, 2009 | 08:52 PM
froggy47's Avatar
froggy47
Mine still does hit the e-brake handle (if it's up) and closes itself (usually on my hand).
I guess it's supposed to be auto closing.
To Opening the console lid
