Corbeaus installed :) some pics
The stock seats with rails are ~40 pounds each. The Corbeau driver side with bracket is 26 lbs, the passenger side with bracket is 22 lbs.
Still a fairly good weight off the Vette.
If you want to save more weight, non-pop up headlights take away 40lbs, and non-run flats will also be a bit lighter...
I think WA and BC should have a joint car meet...we're close enough. Of course, it would have to be in BC
Cheers, IndyPS: I'll have to fill in my profile...but I've only been a member for 10 years...it takes a while
). Corbeaus are great! Really good support (you can take corners without having to worry about slipping off the seat), and they're not as uncomfortable as I thought
It is a bit harder getting in and out, but I'm still young (for now...). Summary: great mod
You seem to imply that they would have worked with the stock power brackets ,but you made your own, for the reasons described.
But they will work with the stock power brackets?
Unless I missed it.. What model of seat is that?
Thanks for the good info.
I already had the stock bracket disassembled from the seat, because that was my original plan. But for me, I don't care about the electronic adjustability, the stock brackets weigh a lot more, and they're a bit higher than I prefer. So I decided to make my own brackets. I'm sure you could modify the stock brackets (some cutting and welding may be required) to fit the Corbeau seats. I believe that fiberglass/carbon fibre shell seats are easier to mount on the stock rails, since they are bolted to side brackets which can be easily attached. They will be a lot higher though, and I'm quite tall...
With the brackets I have, I can move the seat back and forth, and I can use washers to adjust the incline. That's good enough for me.
Do a search. There's lots of people who have mounted racing seats on the stock rails. Hope that answers your question
Cheers, IndyOh, and it's the Corbeau Forza. There's also the Forza 2 (wide version), but I REALLY DOUBT it will fit. Even the Forza is a tight fit (in terms of width).
Thanks for a good write-up.
ZR1991, I think the stock rails will work, but you will have to do some minor fab work (unless, as I said, you buy fibreglass/carbon fibre shell seats, then the install should be a snap). Or buy brackets from Corbeau, Sparco, etc...made especially for the Vette (they sell these, but cost around 100 dollars). Hope that helps
If I were you, I'd just buy the seats, then test them on the stock bracket. If there's no way you can mount them, order the ones for the Vette.
