[Z06] POLL: Do you like D-Type Steering Wheel for C5??
We are more active on C6 forum and rarely come to C5 forum so you may not be familiar with us yet.
Lately we introduce our beautiful Carbon D-Type Steering Wheel for C6 and get excellent response. We also get inquiry from some C5 customers.
We are thinking to make the D-Type Steering Wheel for C5 but we are not sure if C5 customers will be interested so we would like to run this poll. We like to hear your feedback.
The D-Type Steering Wheel is very sporty and more and more high end European sport cars are using it. Because we have to invest expensive mold then we use it to convert the stock C5 steering wheel to the sporty D-Type Steering Wheel, if we don't feel optimistic demand then it won't pay us to go for it.
The standard spec is---- Carbon on the top, left & right is perforated alcantara and bottom is solid alcantara.
If you like to have regular black leather instead of alcantara, we can make it for you too. If you don't want the carbon, we can make the whole wheel in alcantara or leather.
Since we don't have D-Type Steering Wheel for C5 yet, so we can only use the C6 D-type Steering Wheel to show you the concept.
Because C5 steering wheel has 4 spoke, so it will still have the 4 spoke but the bottom will be horizontal to ground so it will look like "D" shape. Please use some imagination.
Here are some C6 D-Type Steering Wheel pictures for your reference. Please let us know your opinions.
personally if it looks anything like the stock wheel, I wouldn't like it very much. But if it looks more like a C6 then I would love it.
I want a different, thicker wheel with a smaller diameter.
BTW, great job on the C6 wheel.
There is a market for a better wheel. But in order to be a success, the following things should be met.*smaller diameter
*thicker rim
*installs like stock
*retains airbag
*high quality
*looks good
We don't want to make new airbag to fit with the new steering wheel. It will be too costy to make new airbag with limited demand.
I don't know if you guys are familiar with the Mercedes AMG style. It will be thicker, more sporty, with grip, comfortable ...etc. If we go with that route then we can satisfy most of these requirements except smaller ring.
Thanks for the thumb up.
We will look further into it to see if we can somehow reduce the diameter and at the same time we can reuse the airbag. It's a tough compromising job.
One suggestion - see what it takes to modify the C6 steering wheel frame to fit the C5 steering column. If there is a difference in the airbag connector, that will not be a big deal to rewire or modify.
I have worked on airbags for years and the wiring is actually very simple. I would purchase a new or used C6 steering wheel (or any other smaller diameter, good-looking steering wheel) in a hearbeat that could be modified by someone to fit a C5.
We will try our best to reduce the diameter. It seems this is the most common complaint from C5 customers. I didn't know about this issue before.
