2000 c5 Optima Battery Issue
Old Jan 13, 2009 | 01:34 PM
NC_Niners's Avatar
NC_Niners
Default 2000 c5 Optima Battery Issue
I bought a brand new Optima red top Model - SC34U for my 2000 C5 Vette. When I try to start it nothing happens. If I take off the connection and reconnect it sometimes it will then kick over and start.
I just got a brand new motor, Alternator, Starter, and now this is the new battery. Did I buy the wrong one?
Old Jan 13, 2009 | 01:48 PM
NC_Niners's Avatar
NC_Niners
It won't even try to kick over. Then if I unhook and reconnect the battery it works the first try. But once you turn it off, even if its right after you start it you have to do the unhook setup again.
Old Jan 13, 2009 | 02:25 PM
poolboy's Avatar
poolboy
that's a different kind of problem - are there any dash lights that look different between when it will start and when it won't? Can you pull the DIC codes to see if there's any clues in there?
Old Jan 13, 2009 | 02:58 PM
Dave68's Avatar
Dave68
Have you checked the ground cable connection? It sounds like the other end may not be tight. chassis ground connections can and do corrode. See
http://forums.corvetteforum.com/c5-t...tion-long.html
for more info.
Old Jan 13, 2009 | 03:27 PM
Choreo's Avatar
Choreo
Very strange?
Might Double check your Optima Model Number... I am not familiar with that Model Designation SC34U?
I have had two Red Tops in my 2001 - the first one did not show a Model Number, but it was a 75/35 - CA-910, CCA-720, RC-90
I just installed a new Red Top last summer (preemptive maintenance)... it shows to be Model No. 7586DT. It is also a 75/35 and all the other specs listed above are the same.
Old Jan 13, 2009 | 03:39 PM
homewrecker's Avatar
homewrecker
Originally Posted by Choreo
Very strange?
the model number is not familiar to me too. Do a search and the majority of people with Red Tops have the same model #
calling Jay, I mean Hotwheels57!
Old Jan 13, 2009 | 03:46 PM
Choreo's Avatar
Choreo
Here is my current battery (ignore the auxiliary terminals I added to the top and the battery terminal wrench)...
Old Jan 13, 2009 | 03:57 PM
poolboy's Avatar
poolboy
I bought a brand new Optima red top Model - SC34U for my 2000 C5 Vette. Did I buy the wrong one?
Looks like you got the right one - Optima Red top Battery (12v SC34U Group 34/78).
Are your battery cables OK - the early C5 batteries had a habit of leaking (pos terminal) - sometimes the acid got into the cables. I am really reaching here, but you do have a unique problem...
Old Jan 13, 2009 | 08:14 PM
wisvette's Avatar
wisvette
I had a similar problem after I installed my red top. Periodically it would not start, would not even take a charge. I had it tested and it tested fine. What I did was clean the battery cable terminals real good and make sure the battery connection is good and clean also. Once I did that I had no problems. Just my two cents.
Old Jan 13, 2009 | 09:32 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
I had a explorer with the same kind of problem. It turns out that the battery cables were corroded inside. From the outside they looked perfectly fine, once we figured out what it was replaced the cables and it worked perfectly until the day I traded it. Have you tried replacing the cables? You may be just temporarily making a good connection when you take the cables on and off.
Old Jan 14, 2009 | 11:00 AM
NC_Niners's Avatar
NC_Niners
I did the Option's then Fuel 4 times trick to get the codes.And I got an error code that is for Battery Circuit 1, and Battery Circuit 2. Anyone have any knowledge on what that means?
Old Jan 14, 2009 | 12:49 PM
NC_Niners's Avatar
NC_Niners
Anyone know what this might be?
Old Jan 14, 2009 | 08:05 PM
duane ratliff's Avatar
duane ratliff
Default Phantom Voltage
35 years ago I had the same problem . the volt meter would show voltage, but was dead when i hit the starter or would not start . it was oxidation . sounds like you need new cables because you can't see inside the insulation like i couldn't an this will cause the intermitent or phantom voltage you are having . good luck . duane # 122540 born 3-6-00
Old Jan 14, 2009 | 09:07 PM
Fast Cop's Avatar
Fast Cop
I bought a Wal-Mart battery (69.99) for my 00 vert and have not had a single problem since install.
To 2000 c5 Optima Battery Issue
