Scuff Marks
Old Jan 14, 2009 | 09:03 PM
LuvTheFuss's Avatar
LuvTheFuss
Default Scuff Marks
I ran a slalom course with the vette last weekend, and like a dumba$$, I caught a cone with the right front fender. Now I have some black marks from the cone. What is the best way to get this off of the car?
Old Jan 14, 2009 | 09:08 PM
Ryan040675's Avatar
Ryan040675
I've always had good luck with turtle wax "clear coat polish". It's mildly abrasive, so just use a little on a wet rag. It's taken a lot of junk of people's cars I've used it on. Comes in a green can and runs about 2 bucks.
Old Jan 14, 2009 | 09:12 PM
Fast Cop's Avatar
Fast Cop
Try a clay bar, I found that it works for even the harshest marks. Good luck!
Old Jan 14, 2009 | 09:51 PM
71vetteinva's Avatar
71vetteinva
I'd try a clay bar and if that doesn't work, then I'd either buy or borrow a random orbital buffer and remove it using some paint cleaner or scratch remover.
You could also try a applying a scratch remover by hand like Meguiar's Scratch X, machine will obviously work better. Don't worry a random orbital buffer won't damage you paint.
I've had good luck with Meguiars Paint Cleaner when applied with a buffer, but there are many paint safe products out there you can try.
Old Jan 14, 2009 | 10:49 PM
bencini231's Avatar
bencini231
very good tips
Old Jan 15, 2009 | 12:41 AM
Jacks02's Avatar
Jacks02
Yes, all good tips. You can also use WD-40 at first, followed with aforementioned Turtle wax.
Old Jan 15, 2009 | 01:10 AM
LuvTheFuss's Avatar
LuvTheFuss
Thanks for all of the help!
Old Jan 15, 2009 | 03:35 AM
billla's Avatar
billla
St. Jude Donor '14
I've always used Goof Off cleaner - a quick wipe and it's gone.
BTW, I call those the "Orange/Black Badge of Courage"
Old Jan 15, 2009 | 08:44 AM
Good tips you've received. Best of luck getting the scuff marks off.
Old Jan 15, 2009 | 09:47 AM
Mikey37's Avatar
Mikey37
I would use 3M rubbing compound (not any other brand rubbing compound; it has to say safe for clearcoat on it) it is equivalent to 1500 grade sand paper. works like a charm for minor scuffs. just make sure you wax afterwards.
Old Jan 15, 2009 | 10:29 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Old Jan 15, 2009 | 01:33 PM
LuvTheFuss's Avatar
LuvTheFuss
Thanks for all the tips fellas! I tried the WD-40 first, simply because it was handy, and it came right off. Thanks again!
To Scuff Marks
