LEDs hyper-flashing
Old Jan 14, 2009 | 10:32 PM
Crow Hunter's Avatar
Crow Hunter
Default LEDs hyper-flashing
I"m sure this has been discussed before, but I am asking again. I installed LED taillights on my '97 about three years ago, and they worked fine - for a few months. Then, when using turn signals, they began to hyper-flash, but not every time. Now, the hyper-flashing has gotten worse, happens every time, and sometimes the turn signals do not work at all. All front bulbs were replaced as a precaution, as a burned-out bulb in front can create this. Brake lights, running lights, and hazard flashers all function normally.
I don't like the hyper-flashing, but I can live with that. However, when the turn signals are nonfunctional, it's a big problem, and could be dangerous. It doesn't happen every time, but frequently.
I know you guys have solutions, and I'd greatly appreciate a solution to rectify this perplexing problem.
Many thanks, in advance!
Old Jan 14, 2009 | 10:49 PM
nickwfd92's Avatar
nickwfd92
you need to get a LED flasher with bypass harness. its $50.00 and plugs in under the knee panel under the stearing wheel. this will allow you to have all LEDs and not have hyper flash. Do a Search on Hyper flash and you will find directions on how to install.
Old Jan 14, 2009 | 11:03 PM
jdmvette's Avatar
jdmvette
Night Owl for life
flasher.
bypass.
harness.
Old Jan 14, 2009 | 11:36 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
All you need is right here on this site -
http://www.corvette-enhancements.com/c5_flasher_fix.php
Richard is one of the best vendors on this site and his solution is elegant and simple to install.
Old Jan 15, 2009 | 02:16 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I'd do the Flasher Bypass Harness.
There is also a fix involving the removal of the Emergency Flasher Module and a minor modification. Labor intensive. It's free but you'll lose the light out warning.
Old Jan 15, 2009 | 03:19 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
I installed LED tail lights about 6 months ago. I also had occasional hyper flashing issues. I recently broke down and ordered the led flasher harness from richard at corvette enhancements. Installed it, and it works like a charm. Excellent quality on the harness build also. It took about 10 minutes total to install. very very easy.
Old Jan 15, 2009 | 05:17 AM
csexton's Avatar
csexton
Richard is the best
Chuck
Old Jan 15, 2009 | 08:32 AM
When I had my car I had the LED taillights and Richard sold me one of the flasher harness kits. Installed it and the hyperflash problem was gone.
Old Jan 15, 2009 | 09:58 AM
JonLuvsVettes's Avatar
JonLuvsVettes
Same here.
Old Jan 15, 2009 | 12:32 PM
Suprfun's Avatar
Suprfun
Best $50 you'll ever spend and Richard's service can't be beat!
Old Jan 15, 2009 | 12:57 PM
Crow Hunter
Many thanks for the information. I'll get one of those kits asap.
To LEDs hyper-flashing
