Passive lock/unlock question??
Old Jan 16, 2009 | 02:33 PM
Wicked Whitey's Avatar
Wicked Whitey
Default Passive lock/unlock question??
My 98 C5 seems to have it's own personality.
I have the lock unlock passive mode turned off.
With the keys hanging in the house if one walks anywhere near the car it beeps and locks the doors. Once locked when walking near the car....key fob in the house...it will beep and re lock the doors.
Any suggestions??
Thanx.
WW
Old Jan 16, 2009 | 02:52 PM
Could be the fob is not working rightl. If you have a second fob, try seeing if that one does the same thing. Just be sure the first fob is a long distance from the car so it won't interfere with the test.
Old Jan 16, 2009 | 03:01 PM
poolboy's Avatar
poolboy
whenever I open my FOB, after putting it back together I have to cycle the passive switch a few times to get it working properly again - if you have opened it to change the battery or any other reason, try sliding the switch off then on again a time or two and see if it behaves better then...
Old Jan 17, 2009 | 02:09 PM
duane ratliff's Avatar
duane ratliff
Default wife's fob
Hi , mine did the same . then i found out that my wife's tight blue geans would set it off a times while she was riding or in the house so I bought her a belt loop clip for her keys an the problem went away ? maybe this will help ! duane # 122540 born 3-6-00 torch red-light camel , SSR #6363 born 3-02-04 sling shot
Old Jan 17, 2009 | 02:48 PM
my6thvette's Avatar
my6thvette
I had to do the same thing with mine, after changing the battery.
Old Jan 18, 2009 | 06:20 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I've heard of cell phones doing this as well. Had one on my 95 Vette and the phone would set it off when I was around the car. Keep mine on my 98 turned off and have not had any trouble with it. Did have it go off a few times but found out I kept the keys to close to the car when I hung them up in the house. Moved the keys to a different location in the house farther away from the garage and no more ghosts setting if off.
To Passive lock/unlock question??
