Antenna problem!Help
Old Jan 21, 2009 | 09:09 AM
Borrega's Avatar
Borrega
Default Antenna problem!Help
well i have a problem with my antenna! hopefully someone can lead me to the fixing it path! well my antenna does not go up an down! but i can hear the freaking motor from the antenna running when i turn my car on or off! what could be the problem! also to get to the antenna motor do i have to take off my rear bumper or from inside the trunk to get to it!
Old Jan 21, 2009 | 09:11 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
you can get to the antenna by removing the tailights.
replacing the antenna is very easy, everything can be done from the tailight opening.
Old Jan 21, 2009 | 09:28 AM
Borrega's Avatar
Borrega
For real ... I want to remove the antenna! It looks kind of ugly! Bunch of my friends it looks like a remote car! Or put the antenna all the way down
Old Jan 21, 2009 | 10:41 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I'm planning the DD NAV system upgrade. A few of the new head units from Kenwood/Pioneer are programmable. I'm working with a couple shops to find out whether I can program the antenna to come on only when the radio is on and not when I have my IPOD connected or playing CDs.
Old Jan 21, 2009 | 11:00 AM
RPOZ4Z's Avatar
RPOZ4Z
I have sirius satellite radio in my car, I installed a push button switch in my console to keep my antenna from coming up when the radio is on and I'm listening to satellite.
Old Jan 21, 2009 | 12:35 PM
Z28Johnny's Avatar
Z28Johnny
With no antenna you would have to do some body work and painting to cover the hole. A shorty antenna is an easier, more cost effective route that I think looks much better than stock.
John
Old Jan 21, 2009 | 01:06 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I just put an electric ant. on. Pretty simple and gets good reception. There are threads about the shorties being less than adequate for reception. (pretty much depend on your particular location)
Old Jan 21, 2009 | 02:33 PM
DeeGee's Avatar
DeeGee
How To Replace a Defective Telescopic Antenna
Now this is a simple mod and the OEM assembly with motor is $130+. You'll know you have the problem because the antenna won't fully retract
Parts:
Adjustable wrench
GM OEM Power Antenna Replacement ($13 E Bay).
Make sure the antenna is fully retracted and that the radio is off
Remove the antenna mounting nut located on the base of the mast on the outside of the car. If the mast is bent it may be necessary to cut off the old mast). If you can't all of the plastic cable out as one piece, (sometimes the plastic gets really hard and breaks into pieces then falls down into the motor), you can just pull the motor after you have pulled the mast out and get all of the pieces out. To do that you'll need to take out the outer right turn signal housing.
Turn on the radio and pull out the old mast and serrated cable completely out of the antenna motor. (Note which way the serrations on the cable are facing)
Feed the serrated cable of the new mast into the antenna hole and stop when resistance is felt. (about 12”). Make sure the cable is fed in with the teeth the same way the old cable came out.
Turn the radio off to lower the antenna until the serrated cable catches.. You may have to cycle the antenna a few times until the cable catches the gear mechanism and retracts into the antenna motor.
Replace and tighten the antenna nut into the mast base.
Turn on and make sure that the mast fully extends without binding. Clean the surface of the antenna to remove any adhesive etc.
10 minute job.
If you encounter a stuck mast here’s advice from the mast vendor:
You see the new "Retaining Sleeve" (silver, 2 inches or so, with slots) on the shaft of the new antenna mast, the original one is most likely a little corroded/frozen into the shaft of your antenna No problem : You are in need of what I refer to as the "snap and tap" technique of mast removal
Turn radio on and let cycle to as much extension as is currently possible
Take hold of the thickest metal mast section (closest to fender) with you thumb and forefinger about 2-3 inches above the top of the antenna shaft hole
Push the thickest mast section into the shaft (as much as it will go within that 2-3 inches)
Hold tightly with thumb and forefinger and Snap your Wrist upward.....you will here the mast bottom "tap" the bottom of the frozen in place retaining sleeve (what this is all about) Repeat this over and over again In-Snap-Tap-Repeat Short Firm Bursts of Energy Focusing the energy blow to the point of the tap This will free the retaining sleeve little by little till it comes out completely
Old Jan 21, 2009 | 02:47 PM
Jacks02's Avatar
Jacks02
For replacement mast, contact Antenna MastsRus at 920-686-0644. I just paid $12.99 + $5.00 shipping/handling. Antenna arrived via USPS and it's an exact replacement. This is a subsidiary of Bridgewood Motorsports, 708 North 6th St, Manitowoc, WI, 54220. Hope this helps.
To Antenna problem!Help
