I have an 02 Z and i would like to remove the Body Side Moldings. Has anyone done this before, is it possible to do with out screwing up the paint? If you have done this, what is the best way to do it? What do you have to do to the paint under the molding after removal?
This is one of those topics that get's asked frequently. So, may I suggest you go to C5 Tech and click on search or search this forum (in the red banner).
To find hundreds of past threads, use keywords "body side molding removal" or "bsm removal" or similar.
The removal process is well documented. Most use a heat gun and either dental floss or thin fishing line to remove the moldings. Then use your favorite chemical or finger friction to remove any residual double sided tape. Follow up with polish/wax of choice.
You should know there may be a downside to this if you're not the original owner of the car and it was repainted/repaired by the previous owner(s). Or if the paint beneath is darker than the rest of the car because it hasn't faded.
Some have discovered they had to have paint work done or leave the moldings in place.
I used heat gun/fishing line, followed by clay bar to clean up the goop... unfortunately I have to repaint the doors, but couldn't find that out until I had the first one off...
I used a hair dryer and fishing line. It came out great. But I'm bought the car new and removed them about 6 months after I bought the car and I always keep it garaged so there was no chance of faded paint.
Most guys get them off easily with fishing wire and a heat gun/goo gone
I've only heard of one or two members who had problems. In those cases it was a repaint job that left witness lines because they'd painted with the BSM still in place.
This pretty much covers it. Just take your time and the moldings should come off just fine.
I like the way you didn't just tell the OP to go do a search, you actually gave some good info too.
just finished getting the tape off mine, grab a piece of silicone baking kit and use it to run the tape off, it'll generate a little heat and presto the tape will be gone. I used some 3M adhesive remover as well.
Do the bsm's get damaged from removing them? I am on the fence about whether to remove them or not and would like to know if I can put them back on if the paint does not match underneith, or I liked it better with them on. Thanks!
The sawing action of the floss or fishing line can leave little nicked impressions in the body side molding edges especially if they've been warmed with a heat gun. Keep the floss or fishing line away from the edges as you saw through.
If you apply sufficient heat, the moldings should come off easily without a lot of bending of the longer pieces.
If you intend to sell them, keep that in mind. The only real damage is to the 3M double side adhesive. A buyer of your moldings would need to remove and re-apply new double sided adhesive...
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I damaged both short pieces, then quit for the season. I couldn't see it happening while doing the job. It happens on the underside of the molding. The line was digging into the lower edge and began growing about an inch well into the plastic before I caught it. The only reason I noticed it was because the progress was way slow and hard to pull. I laid on the floor too see upward, and finally saw what was going on. I can fix the damage with bondo and repaint, but this stopped me from going any further until summer.
Thanks for all the info and experiences you all had. I'm not in country right now and do not have the time to do a lot of researching, so i do appreciate the comments.
