Harmonic Balancer wobble: *video*
Old Jan 26, 2009 | 10:14 PM
Kens86's Avatar
Kens86
Replaced mine this past fall with a Powerbond unit that matched the OEM HB. Very happy with how true it runs.
The Dorman OEM unit was not available at any of the parts houses and only a few dealers had them on the shelf at a premium price. Wouldn't buy one sitting on the shelf for fear it would have the same issue in time. Called the factory directly and they were just scheduling a new run of them this past November. Hope they reworked the issue with the rubber isolator ring. There has been a lot of issues with these Dorman units not only on Vettes but on other GM engines.
Old Jan 26, 2009 | 10:47 PM
tsts's Avatar
tsts
Have a factory LS1 balancer with 30K miles when removed for engine swap. Balancer was fine. Price = $50 + shipping if interested.
Old Jan 26, 2009 | 11:59 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Buy a new one before it falls off and either takes out everything in front of it or breaks the end of the crank off. I just bought another stock one when I changed mine. I paid $104 at the local dealer for it.
Old Jan 27, 2009 | 01:32 AM
VETTHOG's Avatar
VETTHOG
Where can I buy a slp/powerbond or any aftermarket HB that is the stock size? All I could find was the under-drive versions.
Old Jan 27, 2009 | 01:48 AM
ColeTrain'sC5's Avatar
ColeTrain'sC5
just go underdrive pulley. They will free up some power and no problems with the wobble anymore. I pulled my balancer when i did my engine build. mine was fine but i wanted to replace it anyway. I still charge just as good with the U/D pulley as i did with the stock one.
Old Jan 27, 2009 | 08:56 PM
Kens86's Avatar
Kens86
Found mine at OReilly's Auto Parts
POWERBOND - New Harmonic Balancer
Item No: PB1117N
$98.99 Each
1 Per Vehicle
1 year limited warranty (View Details)
LS1 ENGINE
G ENG CODE
Old Jan 31, 2009 | 05:54 PM
VETTHOG's Avatar
VETTHOG
Originally Posted by Nasty98
Easy one
The balancer has a rubber isolator ring that has started to shift away from the outer metal ring . Good to replace it with a 25% underdive and a two peice timing cover . That way if you ever want a cam , you not not have to re & re the steering rack again or remove the crank pulley
Thx
Manny@E.C.P
Assuming I buy a 2-piece timing cover, should I replace the oil pump and timing chain when I swap pulleys? Or can I do that later on when I change the cam? My car has just about 70,000 miles.
BTW-Who has good prices for 2-piece timing covers? Thx
-Tim
Old Jan 31, 2009 | 07:10 PM
71vetteinva's Avatar
71vetteinva
I just had this fixed on my car a 2000 with 49,500 miles. The part is currently on national back order, but my mechanic finally found one at a dealer out-of-state. It took about a week to get the part through GM!
I didn't realize they start a new run of them back in November. That explains why the part is so hard to get right now.
Not a cheap repair.
Old Jan 31, 2009 | 07:27 PM
VETTHOG's Avatar
VETTHOG
Not a cheap repair.
I went the aftermarket route. I bought a ASP U/D balancer so I didn't have that problem
Old Jan 31, 2009 | 07:30 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
-Tim
Buy your self a Meling 295 high pressure oil pump and an LS2 ($50)or Coyles timing chain ($100)
.Two piece timing cover Edlelbrock.
Thx and good luck with your project
Manny@E.C.P
Old Jan 31, 2009 | 08:56 PM
niteriderc5's Avatar
niteriderc5
I understand your not supose to re use the stock bolt? Is one supplied when you purchase a new HB? If not how much do they run at the dealerships? I'm still waiting for a proper full DIY write up
Old Jan 31, 2009 | 09:12 PM
VETTHOG's Avatar
VETTHOG
I bought my ASP HB from Hinson Super Cars and it didn't come with a bolt, but the pinning kit from A&A did. So I'm set.
Old Feb 1, 2009 | 01:46 AM
  #33
ColeTrain'sC5
A new bolt from the dealer is like $10-15 if i remember right. Change the front seal too while you have the front timing cover available. It's the one that goes to the crank. I went with a TSP ported and shimmed LS6 oil pump and a LS2 timing set. The LS2 set is much stronger then the LS1 set and you dont have to grind the cover or double gasket it like you would with a Double timing set. That is like $25 or so from GM but i'm not 100% sure on that. Comes with new sprocket and chain. I wish i had gone with a two peice timing cover set
Old Feb 1, 2009 | 02:30 AM
  #34
VETTHOG's Avatar
VETTHOG
I looked at a diagram from gmpartsdirect and didn't see a front seal for the crank.I saw one for the cam....
Would it be a good idea to change out the water pump gasket at the same time?
Old Feb 1, 2009 | 10:40 AM
  #35
E.C.P's Avatar
E.C.P
St. Jude Donor '07
The OEM gasket's on the water pump are paper and tend to leak after time . The new ones are aluminum with a rubber surround . So ya changing them would be a good idea .
Old Feb 1, 2009 | 01:32 PM
  #36
ColeTrain'sC5
hmm idk you may have to ask Gene Culley or go to the dealer yourself. I ordered a seal for the crank that goes on the cover from a local dealer. Maybe it's on a more broke down diagram. I just suggest changing it while your in there is all. You said 70k miles so it won't hurt Also i agree to get the new GM waterpump gaskets. They are aluminum and rubber and are MUCH better then the aftermarket paper ones
Old Feb 1, 2009 | 02:55 PM
  #37
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
GET IT FIXED!!! i went thru the same thing. i now have an ATI harmonic balancer that is pinned, best way to go. a performance shop can get this done for around 300 labor and xxx for parts. figure about 700 or so all said an done. Also, i ended up using an ARP bolt ($25). expensive but worth it for me since i have a race motor).
Do not put this off, if that piece goes, your motor is in danger.
Aj
To Harmonic Balancer wobble: *video*
Old Feb 1, 2009 | 03:59 PM
  #38
K RIPPER's Avatar
K RIPPER
Harmonic balancer/vibration damper main job is to cancel harmonics/vibration in the rotating assembly(pistons,crankshaft ,rods ect) a very important job indeed, it seperating is a worry but the engine damage that can occur is possible and quite substantial(cracked crank spun bearings ect.) if this were my car the only way I'de drive it was if my garage were on fire and I had to drive it out do yourself a favorfix it or park it till you can
Old Feb 1, 2009 | 04:26 PM
  #39
niteriderc5
Okay I'll park it until I have a chance to work on it. BTW any good write ups on the repair?
Old Feb 2, 2009 | 12:39 PM
  #40
B-Vette's Avatar
B-Vette
Manny,
If they ever kick you out of Ontario you can come to Alberta and set up a shop here - great advice there.
