simple fix if your vert trunk does not pop up enough
Old Jan 24, 2009 | 07:14 PM
johnbadami's Avatar
johnbadami
Default simple fix if your vert trunk does not pop up enough
There have been a few posts on adding a spring to the top latch of the lid to help the trunk open enough to get your fingers underneath.
Simple fix without attaching the large spring. Take off the rear center carpeted section that covers the lock mechanism. Next to and slightly in front of the latch there will be a spring with about 1 1/2" extended out with a slight bend. This is the piece that pushes the lid up. With closing and age that piece of spring that sticks out begins to bend downward.
Put pliers to it and bend it back up so it extends above the latch mouth.
The amount you bend it is the amount the trunk lid will raise.
Real easy fix and you can get rid of the spring you added to the lid.
Old Jan 24, 2009 | 07:16 PM
dobewillie's Avatar
dobewillie
cool
Old Jan 24, 2009 | 07:17 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Excellent....thanks. So simple its scary.
Old Jan 24, 2009 | 07:20 PM
csexton's Avatar
csexton
Good info
Chuck
Old Jan 24, 2009 | 07:38 PM
Sting99's Avatar
Sting99
the info came in handy , because I happen to have the carpet removed, so I just went to the garage and bent it up a little and now it pops up about 1/2 in. the spring was pretty stiff to bend up. thanks for the info
Old Jan 24, 2009 | 07:43 PM
itzza427's Avatar
itzza427
Thanks,,I'll have to check that one our,,,My FRC lid is, should we say, a little inconsistent!! This sounds better than hanging a big old spring there!!
Old Jan 24, 2009 | 07:52 PM
johnbadami's Avatar
johnbadami
Additional point.
when you bend the spring up remember to keep it centered or bent towards the latch mouth or it will miss the lid lock.
Old Jan 24, 2009 | 07:57 PM
black 99's Avatar
black 99
Default trunk
I am going to do that tomorrow thanks very
Old Jan 24, 2009 | 08:31 PM
CHUXDRM's Avatar
CHUXDRM
Great tip, thanks! I never added the "spring", just didn't like the looks of that thing. This sounds like a simple fix.
Old Jan 24, 2009 | 08:44 PM
ronjastone's Avatar
ronjastone
great tip. this has been driving me crazy for about 3 months now.
Old Jan 24, 2009 | 09:53 PM
Mojo 97 Vett's Avatar
Mojo 97 Vett
Gonna give it a try tomorrow .
Old Jan 24, 2009 | 09:56 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Great Info... I'll going to have to do that to mine once the snow clears and it get warmer.....
Old Jan 24, 2009 | 10:00 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
If the General doesn't go out of business this year, I think you may be qualified as a design engineer and possibly get a 6 digit salary.
Old Jan 25, 2009 | 12:02 AM
Dave16's Avatar
Dave16
Thanks for th post. Drives me crazy. I knew there had to be a simple fix.
Old Jan 25, 2009 | 12:16 AM
bencini231's Avatar
bencini231
Great post and thanks for the info.
Old Jan 25, 2009 | 01:54 AM
DeeGee's Avatar
DeeGee
Thanks for the tip and I'll give that a try.
At least I won't have to throw away an expensive mod. I think my trunk popper cost all of $3
Old Jan 25, 2009 | 07:06 AM
steve8's Avatar
steve8
Mine still works fine, but hopefully I'll remember this when/if necessary.
To simple fix if your vert trunk does not pop up enough
Old Jan 25, 2009 | 07:53 AM
ecoman's Avatar
ecoman
Did the same thing to mine and works great
Old Jan 25, 2009 | 02:56 PM
tremor1's Avatar
tremor1
Did mine this morning on my Z. Works great now. Thanks
Old Jan 25, 2009 | 03:30 PM
ferrari red vette's Avatar
ferrari red vette
is this the spring i pull? (the coiled looking one on the right)
