Another Tire Question
Old Jan 25, 2009 | 12:24 PM
Triton170's Avatar
Triton170
Default Another Tire Question
I have a 2000 coupe (A4/Z51) with 21000 miles and the original run flat Goodyears. The tires still have good mileage left on them but they are 8 years old. My question, from a safety perspective, is should I replace them now or run them till the wear out. Car is typically used for trips and weekend driving and being from the south where the highways get pretty hot in the summer safety is the primary issue.
Old Jan 25, 2009 | 12:46 PM
oakvillec5's Avatar
oakvillec5
ttt
Old Jan 25, 2009 | 01:19 PM
bucwheat's Avatar
bucwheat
Check tires carefully for any tiny dry rot cracks,if none don't worry, on the other hand you probably don't have but about 3k mile left on them,24k is about all you can expect out of thses tires,I went with Toyo Proxy's, they have longer tread life ,quieter ride and more comfortable but not a run flat either.
Old Jan 25, 2009 | 01:57 PM
Oldvetter's Avatar
Oldvetter
The tire industry is trying to get 6 years as tire life, but aren't having agreement.
Check for cracks on the sidewalls and in the grooves between tread, if none you should be okay. It helps if your car and tires were garaged, Sun is the enemy of tires.
BTW, I get 55,000 miles front tires and 45,000 from rear OEMs. I just took off a second set, that I bought for the polished thinspokes (I had wagon wheels) and they were from a 2000 and I ran them until bald with no problems. I have 118,000 miles on my 1998.
Old Jan 25, 2009 | 01:58 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Eight year old EMT's with 24K are probably pretty noisy and ride like wood, I would think. If for no other reason than to improve ride, handling and quiet - I would consider something else.
There are aftermarket run-flats like the Michelin that will improve all of these areas....it will be like having a different car. There are a lot of choices in various price ranges.
Another thing to consider - if you are even thinking about different wheels other than stock, unless you plan to retain the stock wheel sizes, consider doing it all at the same time to avoid having brand new tires that won't fit your new wheels.
Old Jan 25, 2009 | 02:02 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
My 02 with 10,000 miles on it has the original run flats and they are like new. They handle and ride fine and have no cracks. If your car was a garage queen like mine it probably didn't see much ultraviolet light from the sun so they don't dry rot as quickly. I'm keeping mine until they wear out at about 40,000 miles.
Old Jan 25, 2009 | 02:18 PM
Triton170's Avatar
Triton170
Car lives in a garage so no direct sunlight. Sidewalls look like new but there is some cracking in the grooves between the treads. I will probably go to Michelin P/S Run Flats in the spring and keep the OEM Custom Sport Wheels. Thanks for the information.
Old Jan 25, 2009 | 08:19 PM
Oldvetter's Avatar
Oldvetter
Make sure that is cracking, OEM's have "belt ridges" between the tread.
Old Jan 25, 2009 | 09:57 PM
bencini231's Avatar
bencini231
Old Jan 26, 2009 | 09:07 AM
Triton170's Avatar
Triton170
Thanks for the info.
To Another Tire Question
