Short Throw Shifter for a 98 Coupe
Old Jan 26, 2009 | 01:03 PM
McFence's Avatar
McFence
Default Short Throw Shifter for a 98 Coupe
I am shopping for a short throw shifter but one that takes the Factory Shift **** - want the car to look as close to original as possible.
A fellow forum member has this Hurst shifter for sale - http://www.autopartswarehouse.com/de...243915085.html
Another friend on the forum uses this one - http://www.mgwltd.com/corvette_short..._shifter.shtml and he loves it - but I have heard some say they believe it takes the stock **** and others say it doesn't.
Mid-America and other parts suppliers have this - http://www.mamotorworks.com/corvette-2-327-7343.html and other shifters as well.
Any input on any of these choices?? Quality, ease of install, feel of the shifter ( I kinda like the deliberate notchy feel) and of course about the stock shift ****.
Thank You
Old Jan 26, 2009 | 05:25 PM
cammedvette's Avatar
cammedvette
Default Shifter
I have installed the hurst short throw shifter in my 99 coupe. It does take the stock shifter ****. The feel is pretty good. Much better that stock, removing around 30% of the throw. Springs are a little stiff making it pretty knotchy feeling but very delibrate. I like it a lot. It comes with a couple of sets of springs for your "feel" preference. It also has some adjusable stops to prevent over shifting. Be sure to lock these stops in place with the lock nuts as mine came loose and worked their way down to the point that I could not shift the car.. I was stuck in 4th gear all the way home. Only had to start from a standing start a couple of times but was baaaad for the clutch!!!! Great shifter though!
Old Jan 26, 2009 | 05:32 PM
Hart's Avatar
Hart
Check out the MGW. The best I have seen. No vibration. Solid. Had mine for a year. Street and HPDE's. NOT ONE COMPLAINT. Great Customer Service.
Old Jan 26, 2009 | 07:27 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
B&M here, and it will take the stock ****, although I have and aftermarket! Just installed it with a little help in about 1/2 an hour!
WAY better than stock. Found it in the parts forum $110 shipped!
Old Jan 26, 2009 | 07:35 PM
81c3's Avatar
81c3
+1 for B&M
Old Jan 26, 2009 | 08:01 PM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
Default Short throw
The MGW is a really nice piece. Bolt action feel. A little stiff at first but it does get easier after a few miles. You can order a 15% or the default is the 30%. I have the 30 and the throws are very short. You can also order either the C6 upper shaft or the C5 upper shaft that will allow you to use either the C6 stock **** or the C5 stock **** which is threaded. I ordered both just in case I want to change ***** at some point. These shifter choices are hard to call , much like exhaust choices, they are really subjective. What feels good to you the next guy might hate. So check em out at a car show and see what you like.Good luck with your purchase.
Old Jan 26, 2009 | 08:37 PM
ALLEGRO's Avatar
ALLEGRO
I agree with got2hav1. What one likes, another may hate.
My choice was to cut down the OE shifter. I took a bit more than an inch off the top of the shifter rod, still have sufficient threads to mount the **** and put her back together. The result was night and day for me. Still maintained the effort of the OE unit without the notchy-ness of some of the aftermarket ones. The cost was nothing and yet the results were what "I" was looking for.
Click on the console pic below to enlarge it. You can see the difference compared to stock.
Good Luck and post your choice and results for all of us!
To Short Throw Shifter for a 98 Coupe
