Need help asap
Old Jan 27, 2009 | 06:53 PM
SCBQQSTN's Avatar
SCBQQSTN
Default Need help asap
for those that installed the HID kit from DJmotorsports please help me out. i go to try the lights out and they wont turn on...whats even more funny is that the headlights wont flip up or down anymore...what gives?!?!
Old Jan 27, 2009 | 06:59 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
First DJmotorsports is a good vendor and I am sure they will work with you to fix the issue. There have been a lot of recent posts concerning the headlights not going down after a HIDS install but I haven't seen anything about not going up or down. Silly question, but have you checked the fuses? If not then I suspect its an issue with the ballast or how you may have wired them. Forum Members RadioFlyer, TSAR or JW Motoring are great resources to get help. Good luck
Old Jan 27, 2009 | 07:02 PM
Z28Johnny's Avatar
Z28Johnny
did you get the resistor? The HID's don't properly trigger the relay to raise and lower the headlights. You have to put an inline cheapo light ($3 from walmart) in there or buy the resistor adapter... or so I've heard.
If that is not it, then I agree with the obvious of checking the fuses.
I've got my lights in the kitchen right now. Not sure if I will have time to install tonight or not.
John
Old Jan 27, 2009 | 07:04 PM
c5BlackBeauty
Lifetime Member
Originally Posted by Z28Johnny
did you get the resistor? John
John....you are correct....I said ballast but I meant resistor.
Old Jan 27, 2009 | 07:11 PM
SCBQQSTN's Avatar
SCBQQSTN
John
i am going to reinstall the old setup and see what happens...
Old Jan 27, 2009 | 07:27 PM
Bluefire's Avatar
Bluefire
You also need to change the headlight fuse from 10A to 20A. I would check that before you take it apart.
HTH
Old Jan 27, 2009 | 07:31 PM
SCBQQSTN's Avatar
SCBQQSTN
HTH
....i just took it apart and all works well....im going to wait till tomorrow to tackle this again...im just glad it got back working, i was very mad for about 30 minutes lol
Old Jan 27, 2009 | 07:32 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
If the lights do not turn on at all (Did you do fogs or lows or both?) then you have a problem other than adding a resistor.
The resistor cures the headlight closing problem.
Old Jan 28, 2009 | 12:52 AM
U TOSLOW's Avatar
U TOSLOW
You need to probably change the polarity of the 12v plug, ie get a paperclip and release the female connectors and swap them. I know I had to do this with the JW kit, which was instructed in the sheet that came with his kit.
Old Jan 28, 2009 | 01:00 AM
1FUNVTT's Avatar
1FUNVTT
Another way to by-pass the resistor problem (until you get the added wiring harness) is to turn on the high beam and while it is on, you should be able to raise or lower the headlights. Well worth the resistor wiring harness to avoid this pita steps.
http://www.shop.jwmotoring.com/produ...4&productId=18
To Need help asap
