I have heard both good and bad about resetting PCM. Anyone who HAS done this what is your take on results.
For those that don't know what this does=
The procedure sets your car's PCM back to it's default fuel trim and timing settings, and sets WOT enrichment back to the high octane table if your car has dropped into the low octane table.....
The car will be defaulted back to it's initial startup, idle, part throttle cruise, and WOT fuel and timing settings.
If you do this, let the dealer do it and ask for all of the software updates that are available for your car. Just like computers (which the car's are, just rolling), updates are issued to the software/firmware onboard, but rarely put in.
You can do this by disconnecting the battery for a while. Usually this means the car will run rough for a short while until the computer relearns the engine's operating conditions and re-adjusts all those settings to the existing conditions.
In your example if you have been using low octane gas and the computer has adjusted settings (retarded timing, etc) the computer will also change back to correct settings if you start to use high octane gas. There is no need to reset.
If something has changed in the engine the computer will compensate for the changes by adjusting settings within a range of values. Once it has reached the end of its range the computer can no longer compensate and the engine will not run as well. If you reset to original settings the car may run even worse.
Bill
