[Z06] What mod should I do while installing clutch
Old Jan 30, 2009 | 03:37 PM
chrisorris24's Avatar
chrisorris24
Default What mod should I do while installing clutch
Hey Guys,
I am installing an LS7 Clutch, New Master, Slave, in a few weeks any other reasonably priced perforamance mods I should do at the same time? I already have new shocks and sways. Ideas???
Old Jan 30, 2009 | 03:44 PM
meldog21's Avatar
meldog21
Remote bleeder line for the clutch. You can get the line for less than $100. It helps prevent the dreaded sticking clutch syndrome and can only be installed while the drive line is out of the car. Since you'll have everything apart, don't waste this opportunity for a great maintenance upgrade.
Dog
Old Jan 31, 2009 | 12:18 PM
itsphoenix's Avatar
itsphoenix
Dog
Can you go more into detail about the bleeder line.
Old Jan 31, 2009 | 03:02 PM
givemeurc6's Avatar
givemeurc6
How about a DTE Trans brace, and/or hardened output shafts.
Old Jan 31, 2009 | 06:47 PM
FourG63 97GST's Avatar
FourG63 97GST
its because it is very difficult to bleed the clutch fluid with the drivetrain in place. the line attaches to the where the stock bleeder will be, its about a foot or 2 flexible line that basically relocates the bleeder.
Old Jan 31, 2009 | 09:08 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Another mod, if you havent done this yet, is a ceramic coated tunnel plate frome elite engineering.
it cuts down on some of the heat coming up through the center console and stiffens the frame as well.
I dont know if it is possible to quantify exactly how much of each it does, but it does some.
Old Jan 31, 2009 | 11:18 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Old Feb 1, 2009 | 12:04 AM
versatile's Avatar
versatile
4:10's
Old Feb 1, 2009 | 01:39 AM
Chris.Shea's Avatar
Chris.Shea
Dog
mandatory IMO. I can fit my hands into some tiny spaces and its even a PITA when you try bleeding without. Plus you dont have to lay under it while all the fluid drips on you
DTE brace, left side shaft or both, shifter, Tunnel plate, Axle back exhaust, Scatter shield... the list goes on.
To What mod should I do while installing clutch
