[Z06] "Service Column Lock" ?
Old Jan 31, 2009 | 04:57 PM
mikestrat's Avatar
mikestrat
Default "Service Column Lock" ?
My battery died, and I had to charge it with a battery charger prior to starting.
Now I get the error message "Service Column Lock", and the steering wheel doesn't lock.
Suggestions?
Old Jan 31, 2009 | 05:03 PM
bartsky's Avatar
bartsky
Are you able to drive the car without fuel shutting off?
Old Jan 31, 2009 | 06:05 PM
jclarksnakes's Avatar
jclarksnakes
Find out if any of the three different Chevy column lock fixes have been applied. All of them are suspect. If the car had a CLB you would not be having this problem.
Old Jan 31, 2009 | 06:14 PM
bob guzzy's Avatar
bob guzzy
Try takeing one of the battery cables off, for a little while, give it some time and put it back on and give it a try.
Old Jan 31, 2009 | 06:41 PM
mikestrat's Avatar
mikestrat
The car runs great.
How can I found out if one of the fixes has been applied? What's a CLB?
I'll try taking one of the cables off.
Old Jan 31, 2009 | 07:20 PM
mikestrat's Avatar
mikestrat
That did the trick! Thanks.
Old Feb 1, 2009 | 05:40 AM
jclarksnakes
Originally Posted by mikestrat
The car runs great.
To see if one of the column lock fixes have been done by a Chevy dealer get someone get the GM service record for your car. If you know someone working in the service department at any GM dealership they can do it for you. If not post and ask on this forum and perhaps someone will get it for you. CLB is a column lock bypass. The column locks in these cars have a propensity to fail. When they do it can strand you with a locked up steering column that will not release. All of the fixes that GM has come up with to fix the defect have pretty high failure rates and when they fail they can also strand you. Get a CLB and install it yourself and be done with the problem. Read the very long sticky on Column locks at the top of C5 forum.
Old Feb 1, 2009 | 08:19 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I got the dreaded message when my OE battery died but was given a second chance once I put in a new battery. It probably takes more time to read the sticky than it does to install the column lock bypass.
Old Feb 14, 2009 | 05:59 PM
Hatchet's Avatar
Hatchet
I am up this particular creek...
The battery in my 03Z is croaking and I got the "Service Column Lock" message. I have COH CLB on the way and plan to replace the battery.
I'm also getting a battery tender as I am tired of the dead battery syndrome week after week. Sadly, the vette is not a DD as I have a work car that I'm required to drive.
Oh well, pretty easy fixes all things considered (knocks on wood) so I forsee a weekend project or two ahead!
To "Service Column Lock" ?
