Harmonic balancer help
Old Feb 3, 2009 | 08:13 AM
TXCyberSport's Avatar
TXCyberSport
Default Harmonic balancer help
Has anyone replaced the harmonic balancer with the attached pulley? the rubber seal around the pulley seems to be pressing out and it is making the pulley wabble quite a bit. Is it a quick easy jobe to remove and reolace it?
Old Feb 3, 2009 | 08:56 AM
Jims79's Avatar
Jims79
I purchased all the parts and looked at the car on a lift & backed away. I would have tried it if I had help from someone that did the job before. Figure when I get my headers and cats installed the shop can do a new pulley. Anyway I'm selling all the parts for a lot less then I paid. G/L
Old Feb 3, 2009 | 09:04 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Not an easy job. The steering rack has to come out to get the balancer out. I would find a good Corvette shop to have this work done. Englandgreen did mine.
Old Feb 3, 2009 | 01:54 PM
warren s's Avatar
warren s
I just replaced my balancer - its not a fun job, but not terrible.
Do a search on balancer replacements - its a hot topic with lots of links and how to's
Old Feb 6, 2009 | 05:25 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That was 2 years ago and I still remember that job like it was yesterday
Fred
Old Feb 6, 2009 | 05:29 PM
diyguy's Avatar
diyguy
I wouldn't touch that as a 'garage project' using YOUR 10 foot pole!
If you DO decide to tackle it just make sure and 'pin' the new one on to the crank as they tend to have a nasty habit of spinning loose.
Old Feb 6, 2009 | 08:56 PM
Chris Stewart's Avatar
Chris Stewart
Especially getting that pulley off and then re-torque to 240lb-ft. without the wheels or flywheel turning.
I used this page as a guide, very helpful if you go for it. http://www.ls1howto.com/index.php?article=2
Old Feb 6, 2009 | 09:11 PM
oaks99's Avatar
oaks99
i've done 2 and they are a pita
later oak
To Harmonic balancer help
