Remove fuel rail covers
Old Feb 5, 2009 | 10:28 AM
MURPHY55347's Avatar
MURPHY55347
Default Remove fuel rail covers
Thinking about replacing my fuel rail covers and I am curious about how they are held on. My usual method of operation is is to break things first and ask questions later. Thought I would try a different route this time!
Old Feb 5, 2009 | 10:29 AM
jrose7004's Avatar
jrose7004
Pull up from the bottom.
Old Feb 5, 2009 | 10:44 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
They will come right off by simply pulling on them. I grab them on the top and bottom and pull. They are held on by permanent type clips.
Old Feb 5, 2009 | 11:19 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
There are spring clips that attach the covers to the fuel rails. Just a sharp tug at the bottom of the cover should release it. The cover on the passenger side of the vehicle, has the oil fill running through the cover - remove the cap on the oil fill just as you were going to add oil before removing that cover.
Once you replace your fuel rail covers, whether you paint them yourself or buy some already painted - it helps to wrap the fuel line on the driver's side with blue painter's tape to avoid scratching the new fuel rail cover.
Old Feb 5, 2009 | 12:14 PM
MURPHY55347
Thanks for all your help guys.
Old Feb 5, 2009 | 12:26 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Old Feb 5, 2009 | 01:27 PM
MURPHY55347
Thanks a pricture really is worth a thousand words.
Old Feb 5, 2009 | 05:12 PM
Old Apr 18, 2016 | 10:04 AM
corvette312's Avatar
corvette312
On the driver side do you have to remove that line or can you remove the cover by putting that line thru the slot opening that the driver's side have ???
Old Apr 18, 2016 | 10:09 AM
jd911's Avatar
jd911
You do not have to remove the fuel line. Once you get them popped loose, you'll find they are soft pliable plastic, akin to tupperware. You can hold both sides of the slot and bend the cover to open up the slot for added clearance. When I mean bend, I don't mean side to side. You bend one side up and the other side down.
Jim
To Remove fuel rail covers
