Does Your Vette Have Floppy Ears?
We have 11 sets in stock of our new reproduction sun visors. These are a high quality and have been manufactured to original factory specifications using today's modern manufacturing techniques. Grab your set today or just one!
$99 per side or $198 per pair.
Order here:
C5 Sun Visor Pair
C5 Right Visor
C5 Left Visor
Here are the instructions from the GM service manual:
Sunshade Replacement
Removal Procedure
1.Tilt the sunshade down toward the windshield.
2.Insert a flat head screwdriver blade into the slot in the sunshade inner bezel.
3.Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages).
4.Push up on the sunshade and continue rotating the sunshade outboard until the sunshade with the inner bezel disengages from the mounting bezel.
5.Disconnect the electrical connector.
6.Remove the sunshade.
7.Disassemble as necessary.
If removing the mounting bezel, pull the bezel from the garnish molding with your fingers.
If replacing the inner bezel, remove the bezel from the sunshade shaft and press the new bezel onto the shaft.
Installation Procedure
1.Route the harness through the mounting bezel.
2.Insert the mounting bezel into the garnish molding engaging the snap fingers.
3.Connect the harness to the sunshade electrical connector.
4.Push the connector up through the bezel and through the hole in the garnish molding.
5.Position the sunshade approximately midway between the windshield and the side of the vehicle.
6.Insert the rod with inner bezel firmly attached fully into the mounting bezel.
7.Rotate the sunshade toward the center line of the vehicle until the sunshade locks in place.
(sunvisors) is that the cover for the vanity mirror won't stay shut when they're all the way up with the roof panel out. I think I'll just use a sliver of double sided tape, it's the driver side and I never use it anyway.
Well if it ever gets to bad you know where to get them in the future.
After chuncking the screwdriver across the garage, then having to pull it out of the wall
i finally cooled down enough to think the problem through. I then took the targa top off the car, pulled the upper inside windshield trim back a little, sprayed some WD40 on the inside of the cup that houses the visor rod. I then got one of my gallon paint can openers to put in what was left of the slot. The slight bend on the end allowed it to grip into the plastic piece and the visor came out with ease. Wished i would have thought about the WD40 first before all the aggrivation began. They do look great. Hope this helps somebody.
I sure could use a set. My drivers side is shot and needs to be replaced.
mine too so I just fold them under
