Which Battery Tender?
Old Feb 6, 2009 | 03:50 PM
hotwheels57's Avatar
hotwheels57
Originally Posted by TooMch
I guess the guys with the battery tender brand are having no problems. That is the one I've seen in stories of fires. Maybe it wasn't true but it was enough that I stayed away from it. My vehicles mean too much to me to fret over the cost of a battery tender so I got CTEKs for both of my summer only vehicles. They work great!
Where do most people clip the clamps to on their C5s? My clips aren't the biggest and they don't like to bite on that little stub sticking out of the side post terminals. I looked around for some kind of extension or adapter but haven't found anything. My other car has top poet and I attached the quick connect eye terminals to the smaller bolts next to the terminals and wish I could do something similar on my C5.
It's obvious from the past threads on (float maintenance) chargers that people tend to use the terms "battery tender" in the generic sense rather than the DELTRAN "Battery Tender" (Plus or Jr.)
The CTEK is a refined European product with more high tech than the DELTRAN products. Either will work just fine.
I've been using a "Battery Tender Plus" full time on at least one vehicle since '95 and it's never failed. I use it on an OPTIMA, which also has caused debates.
You can change the original ring terminals on your CTEK unit to fit the battery terminals on your car. Or you can find extended battery terminals from any well stocked automotive stereo shop.
I haven't purchased from this vendor, but scroll down through this PDF file and you should find an extension that will work with your particular battery style and allow permanent connection to the battery...
http://www.eastpenn-deka.com/assets/...Protectors.pdf
Old Feb 6, 2009 | 04:08 PM
Hot__foot's Avatar
Hot__foot
Originally Posted by Willfulone
CTEK
http://forums.corvetteforum.com/c5-g...-from-cca.html
Set it and forget it...
...plus it has all the safety features you want with a car full of electronics...
Peace
Chip
Old Feb 6, 2009 | 10:39 PM
O4-/-C5's Avatar
O4-/-C5
CTEK
Old Feb 6, 2009 | 10:58 PM
RSuperfreak3's Avatar
RSuperfreak3
Got my CTEK from Tool Outfitters. Cheapest I found anywhere...here is the link...
http://www.tooloutfitters.net/multi-...y-charger.html
Old Feb 6, 2009 | 11:29 PM
PewtVette's Avatar
PewtVette
I'm in my third winter with my Black and Decker batter charger. It was around $40. I picked it up at HD or Lowes- I can't remember which. I'm approaching 7 years on my original batter. The B&D has worked great.
Old Feb 6, 2009 | 11:30 PM
VetteFTW's Avatar
VetteFTW
I just got one for about $40 or so at Pep Boys. Worked like a charm!
Old Feb 7, 2009 | 01:52 AM
PierEagle's Avatar
PierEagle
Originally Posted by RSuperfreak3
Bought a ctek 3300 for my Z and love it. As was said...plug it in and forget it. Even has a break-away conector in case you forget to much and back out of the garage with it still attached . Little more expensive than the others but I want the best for my car.
I worried too about forgetting and moving the car with the charger attached so, anytime I have the charger hooked up, I tie a yellow plastic newspaper sleeve on the steering wheel. Instant reminder.
Old Feb 7, 2009 | 09:49 AM
bigcypress's Avatar
bigcypress
agree with 'dale96' we have 2 and they work great . by the way , you can hook multiple batterys up in a series with this product .
Old Feb 7, 2009 | 10:20 AM
Bills03Coupe's Avatar
Bills03Coupe
CTEK
Peace
Chip
I have the CTEK and it works flawlessly. Fully protects the
expensive electronics in our Vettes. I Highly recommend it! (got mine from Chip!)
