Help - Wheel Lock Problem
Old Feb 7, 2009 | 12:04 AM
EVs_C5's Avatar
EVs_C5
Default Help - Wheel Lock Problem
So my vette has wheels locks but i dont have the key to take them out...how do i source the right size key to remove them?? I know nothing about wheel locks
Thanks for your help guys i appreciate it
Old Feb 7, 2009 | 12:27 AM
HawkIVette's Avatar
HawkIVette
Did you search the trunk area for a key. Looks like a socket.
If you can't find it, go to a tire shop and they will probably be able to get them off or order you the right key.
Old Feb 7, 2009 | 12:34 AM
Ray3's Avatar
Ray3
7th Gear
When i bought my 02 i thought i had the same problem. Then i learned from here to look in a recess area on the left(?) edge of the center well in the trunk. Sure enough!! It was there...Ray
Old Feb 7, 2009 | 09:35 AM
lwise4's Avatar
lwise4
Default Wheel Locks
I had the same problem when I bought mine. The Dealer has a set of Master Keys they tried them until one worked. I them bought a new set for about $30 from the same dealer. Check with your local dealers.
Old Feb 8, 2009 | 12:10 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I have a special socket that is just tapered inside with no flutes or anything inside but the taper. You tap it on and it removes 90+% of the locks. Then just buy a new set. Before I had the socket I just used what ever socket was close enough to force on there and removed them. Worked pretty well.
You could just pay a punk from your hood and he'd have them off in about 10 seconds.
Old Feb 8, 2009 | 12:30 AM
Bill Dearborn's Avatar
Bill Dearborn
When you get them off don't bother putting them back on as only honest people have trouble getting them off. No sense paying good money for something that doesn't really protect you.
Bill
Old Feb 8, 2009 | 07:24 AM
Or a good tire/mechanic shop can get them off without damaging the wheels. You might also look in all your paperwork with the car and see if there is a little card that has the key number for the locks. Then contact the address on the card and they can get you the right one to take the locks off.
Old Feb 8, 2009 | 08:32 AM
Patches's Avatar
Patches
You can see my wheel lock socket in the storage location on the driver's side of the center storage well in the back of the C5. Check there if you haven't before.
Otherwise, try one of the above methods.
Old Feb 8, 2009 | 10:19 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
If you cannot locate the lock anywhere, go to Sears and get the bolt off socket that matches your lock(probably 19mm). They work smooth as butter, and in seconds.
Old Feb 8, 2009 | 05:25 PM
EVs_C5's Avatar
EVs_C5
thanks for all your help guys i appreciate it!!
im going to go check for it in the trunk now!
To Help - Wheel Lock Problem
