Ok so I took my side moldings off of my 04, 99% of the adhesive came off, but if u look closely u can still see a very thing line of it, and its annoying the hell outa me
I googled forums and alls I'm finding is the actually goo adhesive not the little little **** that stays, I tried goo gone and wd40 that **** is so thin its impossible
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I removed mine and it took about an hour and a half and a lot of rubbing. I see your car is black, I am sure that is going to take some real work.
Good luck and hopefully your car hasn't been repainted.
Bill
This might make some cringe but I used fuel oil on mine. The gooey s**t came right off with no problem.
Then I came back with a soap (dawn) and water wash followed up by the clay bar and finally a couple coats of Meguiars Polish. Looked good as new with no tail tell signs of the BSM left behind.
