Problems with Blackwing!
Old Feb 8, 2009 | 07:35 PM
hamptonwskb's Avatar
hamptonwskb
Default Problems with Blackwing!
I recently bought a 99 frc and it already had a blackwing installed on it. The only problem is the previous owner has got it electrical taped or something to the mass air unit. Im afraid to take it off cause I dont think it will seal again. The blackwing unit opening is much larger than the mass air is big if that makes any sense. I thought all blackwings fit 97 to 00 without needing a coupler. Whats crazy is that shouldnt it be reversed if the mass air isnt stock. I mean if the previous owner put a 01 up mass air on then the blackwing opening should be to small not to big. Did Slp use to make 2 different size blackwings. I really dont know what to do. Do I order a new intake or is there a fix for this?
Old Feb 8, 2009 | 08:27 PM
Dave68's Avatar
Dave68
Are you talking about a hose connection? The MAF sensor is strictly electrical. Maybe a picture would help. You may be missing a rubber grommet.
Old Feb 8, 2009 | 08:35 PM
kcbeagle's Avatar
kcbeagle
Kinda scary man...
Post some pictures so the experts here can help. You will be amazed at the quality of info found here!
Old Feb 8, 2009 | 10:21 PM
DsC5's Avatar
DsC5
That is pretty scary. Sounds like he had the wrong coupler, but with the above -- pics would help.
Old Feb 8, 2009 | 10:34 PM
Fire 22's Avatar
Fire 22
I just installed a Blackwing on my 01, there is a rubber gasket for the 97-00 cars that seals the MAF into the filter neck. For 01 and up the MAF is the same size as the filter neck so a coupler is used to butt them together.
Old Feb 8, 2009 | 10:55 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Pics would help
Old Feb 9, 2009 | 11:07 AM
hamptonwskb
Ill get some pics today. I bet Im missing that rubber piece that slides on the mass air. If it came off a 01 up then it wouldnt have the rubber piece correct? Where can I get the rubber piece to fix this? Thanks for the input!
Old Feb 9, 2009 | 11:43 AM
hotwheels57's Avatar
hotwheels57
Have you tried any of the site supporting vendors yet? That's the column to the left.
Try ZIP PRODUCTS, PFYC, SLP ("Blackwing" distributor) to start...
Old Feb 9, 2009 | 01:00 PM
scottydog's Avatar
scottydog
The blackwing usually comes with a black connector to hookup to the MAF. You can get one, or just put the stock filter back on. I never felt the blackwing made much of a difference vs stock.
Old Feb 9, 2009 | 02:54 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
http://www.siliconeintakes.com/inter...e347b2ab7041cf
You probably just need a correctly sized coupler.
Old Feb 9, 2009 | 02:57 PM
Dave68's Avatar
Dave68
If you really want to "wake up" a Blackwing, feed it cold outside air, either by coring out the fog light covers or by cutting the lower radiator cover and installing a screen and scoop combo. My procedure for doing this can be found here:
http://www.conceptualpolymer.com/Rad...op%20inst..pdf
Not having a cold air inlet will guarantee a drop in HP (up to 10 RWHP)during slow-moving and stop & go conditions. The only downside to CAI is having to clean your filter more often.
Old Feb 9, 2009 | 03:15 PM
fireman591's Avatar
fireman591
Here is a set up of my Whitewing on my 1999 coupe.
Old Feb 9, 2009 | 03:21 PM
hotwheels57
What you probably need is the oem style "seal and clamp" shown in these instructions. It's the slip on rubber seal that has a different size ID on either side and is secured with a single stainless worm clamp.
From the SLP website...
http://www.slponline.com/inst/21110.pdf
Old Feb 10, 2009 | 01:05 AM
hamptonwskb
Okay, looking at the pics of the white 99 there I see the black rubber piece connecting the mass air to the filter. I dont have that. Mine is just the hard plastic filter neck taped to the mass air unit. A 01 up coupler wont help. I need that piece of rubber along with that clamp that came with the filter to begin with. Can I get just that part or do I have to buy a new filter?
To Problems with Blackwing!
