Convertible top question
Old Feb 11, 2009 | 02:02 PM
simard's Avatar
simard
Default Convertible top?
You must be talking about the sunshade for the seats to be used when the car is parked. I get it now.
Old Feb 11, 2009 | 02:38 PM
ferrari red vette's Avatar
ferrari red vette
Originally Posted by MSG C5
Absolutely. In fact, one of the worst things you can do for any ragtop is drive at higher speeds (above 30 MPH) with the top up and the windows open. The air that circulates through the cabin puts upward pressure on the top expanding it and causing it to loosen over time.
I've seen this on many late model Mustangs, Firebirds and Camaros where the top has a bubble curve vs. a flat profile.
the bubble is there permanently or while driving?
if it's while driving, it has nothing to do with the top loosening over time. its physics and air pressure. air pressure is lower above, causing the canvas top to bubble. same principle for airplane flight.
Old Feb 11, 2009 | 02:43 PM
Vette310's Avatar
Vette310
My top has a leak on the driver side but I need to get fixed ASAP..
WINDOWS UP TOP UP , WINDOWS DOWN TOP DOWN !
Old Feb 11, 2009 | 02:59 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
It happens while driving, however the bubble is not as extreme when the top is new. It takes time and eventually gets worse and worse the more you drive it with the top up and windows down.
My buddy had a Mustang convertible and when the car was parked or stopped, the ragtop then collapsed downward (opposite the bubble effect) and looked just as bad.
Old Feb 11, 2009 | 03:01 PM
Shinyredone's Avatar
Shinyredone
Stays up on my 2001
Old Feb 11, 2009 | 04:20 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by DAV162
Is it SPRING yet!!!!!!!!
It felt like was it today!
Old Feb 11, 2009 | 04:26 PM
Jet-Jock's Avatar
Jet-Jock
Might as well join in, yep that is the way Chevy designed it.
In my case being a daily driver, it is starting to bleach out from the sun so I believe one can order just that piece and it appears to be an easy install, just torx screws.
Old Feb 11, 2009 | 07:56 PM
dobewillie's Avatar
dobewillie
as stated top up windows up top down windows and never top down and windows up
