Seat Memory Troubles NEED HELP
Old Feb 10, 2009 | 04:45 PM
hfddirty30's Avatar
hfddirty30
Default Seat Memory Troubles NEED HELP
Seat memory does not always work. When entering using unlock on key farb,and inserting key in ignition,seat does not always return to its set position.Everything else is working fine.Has anyone else had this problem,if so could you tell me were to start looking to correct the problem. THANKS!!!!
