C5 Kill switch
Old Feb 11, 2009 | 04:50 PM
hotwheels57's Avatar
hotwheels57
This one from HOTRONICS is probably the slickest. It's fuse protected and you can maintain your electrical power to the computer with a simple jumper wire between two terminals.
It will power your accessories, it just doesn't supply enough power to start the car.
In fact, you could add an inline fuse to the jumper wire which would power your accessories, but blow out should anyone attempt to start the car.
Old Feb 11, 2009 | 04:52 PM
poolboy's Avatar
poolboy
Originally Posted by TraceZ
I live in a high traffic house. Keys are available to anyone. I'd like to keep good people honest and not overtly show any distrust.
Sorry, I didn't get that from your original post - most peeps put kill switches in for other reasons. I would suggest you PM Bill Curlee - he should be able to help you figure out if this will work or not - just be sure to tell him why you're doing it so he doesn't go off in the wrong direction too...
Old Feb 11, 2009 | 04:54 PM
Vega$Vette's Avatar
Vega$Vette
What do you guys think of my original idea to add a simple toggle switch into the VATS circuit? If the circuit is broken with a switch the VATS system goes into "disabled" mode and even the ignition key is useless. It would be just like a crook trying to use a key with no pellet on it.
Sound like it could work?
Why are you fixated on the VATS Circuit. Fooling with that will just open a can of worms. Just switch fuel pump or starter relay if you don't want it to crank.
Old Feb 11, 2009 | 04:56 PM
TraceZ's Avatar
TraceZ
Originally Posted by Vega$Vette
I have one of these on my 55 Chevy. There is a pole that you can run a wire from that stays hot when the switch is off to things like radio memory etc.
I'm pretty sure that there are more than a few live circuits on a C5 when it sits parked. I think trying to integrate a device like this into all those circuits so they stay live when the kill is tripped would be very messy at best.
Old Feb 11, 2009 | 04:58 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Starter...
Peace
Chip
__________________
..................Click for
Old Feb 11, 2009 | 05:02 PM
TraceZ's Avatar
TraceZ
It just makes the most sense to me. The system is alerady there, already designed to prevent the car from starting and looks like it would be a breeze to add a toggle switch. I don't see how cutting a wire and splicing in a toggle switch can open a can of worms.
Old Feb 11, 2009 | 05:44 PM
2003 electronblue's Avatar
2003 electronblue
well a kill swicth could be helpful but what will stop the old fashion tow truck? anyone have low jack?
Old Feb 11, 2009 | 06:42 PM
Oldvetter's Avatar
Oldvetter
TraceZ,
You have an MN6, why not wire into your clutch switch. With it open, you won't be able to start car.
I would worry about extra resistance (switch and wire) in VATS circuit. Probably would be within allowance, but why take the chance?
Old Feb 11, 2009 | 06:53 PM
CCA Corvette Parts
Originally Posted by Oldvetter
TraceZ,
Exactly...
Peace
Chip
Old Feb 11, 2009 | 07:39 PM
TraceZ's Avatar
TraceZ
TraceZ,
I like that idea. Simple and effective!! Now you got me thinking... I just might do that instead.
