C5 Kill switch
Old Feb 11, 2009 | 03:05 PM
TraceZ's Avatar
TraceZ
Default C5 Kill switch
I'd like to install a hidden kill switch in the cockpit of my C5.
I was considering placing a simple one pole single throw toggle switch in line with the VATS circuit to the ignition lock cylinder. When the switch is in the on position the VATS system works as normal. When the switch is in the off position the VATS system will not see the resistor pellet in the key and disable the car accordingly.
Thoughts? has anyone ever done this?
Will adding the wire and switch change the resistance in the VATS circuit enough to cause an issue that may be seen as an incorrect pellet value?
Old Feb 11, 2009 | 03:59 PM
OKsweetrides's Avatar
OKsweetrides
I might have to go and play with this idea. I would love to have a kill switch.
Hoping to hear from others on this issue as well!
Old Feb 11, 2009 | 04:06 PM
chris308's Avatar
chris308
what about putting a switch inline with the fuel pump circuit. would be easier than messing with the vats system, no?
Old Feb 11, 2009 | 04:11 PM
Vega$Vette's Avatar
Vega$Vette
Why?
Old Feb 11, 2009 | 04:16 PM
Sinister-one's Avatar
Sinister-one
If none of you smoke, you can try using the cig lighter. When you park the car, push in the llighter and VIOLA, power killed. To re-enable the power, pull the cig lighter back to it original position.
Ehh... ehh... ehh.... not a bad idea huh !!
Old Feb 11, 2009 | 04:23 PM
TraceZ's Avatar
TraceZ
I'm thinking using the existing security system would be more proper. This way the security light in the dash will be a valid indicator.
hotwheels57's Avatar
hotwheels57
Do some research in the street rod products available. There are mechanical and electrical disconnect switches.
This one from HOTRONICS is probably the slickest. It's fuse protected and you can maintain your electrical power to the computer with a simple jumper wire between two terminals.
http://www.hotronicsproducts.com/
From COLE HERSEE...
From FLAMING RIVER...
Old Feb 11, 2009 | 04:25 PM
poolboy's Avatar
poolboy
A kill switch is a good idea, but only to disable the VATs? If someone is going to jimmy the switch it won't matter that VATs is disabled will it? Why not one that cuts power or something like that? I'm confused?
Old Feb 11, 2009 | 04:27 PM
DevilMan02's Avatar
DevilMan02
Sigh. I posted this in the technical section. Lots more feedback here. Go figure.
Old Feb 11, 2009 | 04:28 PM
Vega$Vette's Avatar
Vega$Vette
This one from HOTRONICS is probably the slickest. http://www.hotronicsproducts.com/
http://www.parts123.com/parts123/yb.dll?parta~partsort
from Julianos Hot Rod Parts is the same for only $65.
Old Feb 11, 2009 | 04:30 PM
TraceZ's Avatar
TraceZ
No no. Not to disable the vats, to work in line with the vats.
If the switch is tripped, it actually forces the VATS to activate, disabling fuel as well as spark. I think it would also prevent the engine from cranking.
Old Feb 11, 2009 | 04:31 PM
Merlin02's Avatar
Merlin02
Maybe this will work?
http://www.emergingent.com/vandalale...rt_nostart.htm
TraceZ's Avatar
TraceZ
Originally Posted by Vega$Vette
Why?
to keep good people honest.
Old Feb 11, 2009 | 04:33 PM
TraceZ's Avatar
TraceZ
From COLE HERSEE...
These are battery disconnectors for race cars. I'm looking for something small and hidden to prevent the car from starting with the key. Thanks for trying to help though.
Old Feb 11, 2009 | 04:35 PM
Vega$Vette's Avatar
Vega$Vette
I'm still not getting it. Why would you not want it to start with the key?
But if you really want to do it just put a hidden toggle switch in the fuel pump circuit.
Old Feb 11, 2009 | 04:38 PM
hotwheels57
Did you notice that the first example has a micro toggle switch that can be placed anywhere in the car?
With the switch on, the car will not start at all.
Old Feb 11, 2009 | 04:41 PM
TraceZ's Avatar
TraceZ
I live in a high traffic house. Keys are available to anyone. I'd like to keep good people honest and not overtly show any distrust.
To C5 Kill switch
Old Feb 11, 2009 | 04:42 PM
TraceZ's Avatar
TraceZ
But it would also cut power to the PCM, causing it to forget long term fuel trims and similar learned programming. It would have to start from scratch relearning itself every time you started the car.
Old Feb 11, 2009 | 04:46 PM
TraceZ's Avatar
TraceZ
What do you guys think of my original idea to add a simple toggle switch into the VATS circuit? If the circuit is broken with a switch the VATS system goes into "disabled" mode and even the ignition key is useless. It would be just like a crook trying to use a key with no pellet on it.
Sound like it could work?
Vega$Vette's Avatar
Vega$Vette
I have one of these on my 55 Chevy. There is a pole that you can run a wire from that stays hot when the switch is off to things like radio memory etc.
