Electric gremlins. . .
Old Feb 14, 2009 | 11:24 AM
killain's Avatar
killain
Oldtimer
Default Electric gremlins. . .
I have't use my corvette in a month, it was hooked up to a battery tender, and today i took it out to run some errands, and the seat memory doesn't work and the dash lights are dim and the HUD is low, I drive it for about twenty minutes starting and stopping five times and now everything is back the way it was? How can that happen?
Old Feb 14, 2009 | 12:11 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
How old is your battery? Even if it was on a tender, if the battery is getting long in the tooth the tender can only do so much. Are you sure the tender works properly? Most of what you described sounds like a weak battery. I would also drive it further.
Old Feb 14, 2009 | 03:23 PM
killain's Avatar
killain
Oldtimer
The battery, a Optima Red Top is 2.5 years old and yes the lectriclimited 'batterybutler' charger works. I forgot to mention, I had the battery 'Load tested' last fall and it tested fine.
Old Feb 14, 2009 | 03:30 PM
ALLEGRO's Avatar
ALLEGRO
Well obviously something is not right. The battery is not "old" but that does not ensure that it is "good." I would check the voltage at the batter before and after starting the car with a reliable volt/ohm meter. Then, I would check the voltage after the car has set a few days on the charger. Somewhere things are not correct, lots of places to look.
Good Luck
Old Feb 14, 2009 | 03:52 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Corrosion under your terminals or ground point?
To Electric gremlins. . .
