Over sized tire question
Old Feb 14, 2009 | 02:03 PM
Rich-L's Avatar
Rich-L
Default Over sized tire question
I am planning on putting 255/40ZR17's and 285/35ZR18's on a 2004 convertible. Rims are original GM thin spokes. Tires are Goodyear GS-D3.
Am I going to have any issues?
Old Feb 14, 2009 | 04:31 PM
jwd1011's Avatar
jwd1011
Should be fine, I have seen people on cf that have 255's on the front, and I personally have 295's on the back of mine.
Old Feb 14, 2009 | 04:43 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Old Feb 14, 2009 | 05:00 PM
Rich-L's Avatar
Rich-L
Thanks for the comments, will the 295/? fit the stock rim?
Old Feb 14, 2009 | 05:03 PM
Bugaboo's Avatar
Bugaboo
yep.
Old Feb 14, 2009 | 06:24 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
A local member had Z06 sizes on his thin spokes with no issues....
Old Feb 14, 2009 | 11:35 PM
jwd1011's Avatar
jwd1011
Yes, a 295 fits well..I like it
Old Feb 16, 2009 | 11:07 AM
Rich-L's Avatar
Rich-L
Thank you all for your comments, I am going to bump the rear's to 295.
Old Feb 16, 2009 | 12:18 PM
ultradriver10000's Avatar
ultradriver10000
I have had 265/295s on Y2Ks no problem. Right now I have 285/35/18 on a 9.5" wide rim and 295/40/18 on a 10.5 wide rim.
Old Feb 16, 2009 | 12:37 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Just try to make sure that they are not more than a 1/2" TALLER OR SHORTER THAN THE ORIGINAL STOCK TIRES!
If they are and you get codes you will need to have the PCM programmed for the correct tire height
Thanks,Matt
To Over sized tire question
