Help! Gas Leak...
Old Feb 18, 2009 | 08:37 AM
travelingypsye's Avatar
travelingypsye
Default Help! Gas Leak...
It was nice out yesterday so I decided to drive the car. This morning, at 5am there was a puddle of gas under the driverside rear & behide it. Now( 8:30) the puddle is gone but the smell is still real bad. I will open the door & air it out but I am afraid to start the car to pull it out.
Has anyone had a gas leak b-4. I don't remember reading about one. The tank was about 1/3 full when I parked it yesterday. Any thoughts? Thanks.
Old Feb 18, 2009 | 10:45 AM
bucwheat's Avatar
bucwheat
The fuel filter is on the drivers side frame rail I had mine start leaking,change it and make sure the hose clamps are in good shape.
Old Feb 18, 2009 | 10:51 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Agreed. The fuel filter is the first suspect. You shouldn't dare drive it till its fixed due to major safety issue since the exhaust pipes are right there. The second suspect is the cross-over tube.
Old Feb 18, 2009 | 11:21 AM
travelingypsye
Thanks.
That was my first thought but I didn't know where it was at.
Old Feb 18, 2009 | 12:19 PM
Indy's Avatar
Indy
Yes, like someone said before....Don't drive....gas and hot exhaust are a bad combo!!!!
Old Feb 18, 2009 | 03:24 PM
DeeGee's Avatar
DeeGee
There seem to have been a lot of fuel leaks recently. I took a look at the book and there are a few connections that could leak.
Start by examining the fuel filter connections next to the exhaust system.
The main fill pipe routes from the cap to the tank. There’s a connector at each end of the fill pipe. One of the early problems was slow filling and GM redesigned the fill pipe to get a better flow.
1. Fuel filler hose
2. Vent pipe
Next check the fuel sender, the aux fuel rear return pipe that connects the jet pump to the left tank and the aux fuel feed rear pipe that connects the left tank to the jet pump at the fuel sender. The FLVV hose routes to the EVAP canister. Finally the crossover pipe connects the two tanks but that’s at the top of the tank so I guess it would be hard to see from below.
1. Auxiliary fuel return rear pipe from the jet pump to the left tank.
2. Fuel return rear pipe.
3. Fuel feed rear pipe at the fuel sender
If the leak doesn't show until the tank is getting full that would be the time when the fuel is starting to fill the right tank via the crossover pipe. It may give a clue.
1. Left fuel tank EVAP pipe.
2. EVAP pipe quick-connect fitting.
5. Tank crossover hose 1. Left fuel tank EVAP pipe.
I've never looked in there so not sure how easy it will be to see all these connections but I'd guess you'd need to get the car up on a lift.
HTH
Old Feb 18, 2009 | 05:29 PM
travelingypsye
Dave,
Thank you for such a detailed imput. Once again, you provided exellent info.
To Help! Gas Leak...
