[Z06] Need quick answer about lowering on stock bolts
Old Feb 19, 2009 | 01:59 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Default Need quick answer about lowering on stock bolts
Are the fronts turned counter clockwise, and the rears clockwise? Vice versa? Both the same way? Also, if I lower each bolt to the max, should the ride height come out even?
Thanks!
Old Feb 19, 2009 | 02:04 PM
pb24dagrk's Avatar
pb24dagrk
Old Feb 19, 2009 | 02:25 PM
hotwheels57's Avatar
hotwheels57
The front and rear adjustment bolts are RH thread. Where people tend to get confused is how they position themselves when adjusting the bolts.
All rules of RH thread fasteners apply.
Basically, your goal when lowering is to end up with less threads showing on the rear bolts at the top, and more threads showing on the front bolts at the top.
Old Feb 19, 2009 | 02:26 PM
Iron Chef's Avatar
Iron Chef
St. Jude Donor '06-'07-'08-'09
CI 8-9-10 Veteran
For Pete's Sake...
If you don't have anything constructive to add to the thread without being rude or condescending...stay out of it.
If I have to hand out vacations to make folks understand, that can be arranged.
Old Feb 19, 2009 | 08:14 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Originally Posted by Iron Chef
For Pete's Sake...
I apologize for the profane language, but that was just uncalled for.
Thanks!
Old Feb 19, 2009 | 08:15 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Thank you, sir.
Old Feb 19, 2009 | 09:32 PM
ctusser's Avatar
ctusser
It's recommended that you have 2 threads showing in the rear. This will allow for a little rake (rear slightly higher than front) which will add aerodynamic stability at highway speeds and above.
Old Feb 19, 2009 | 09:37 PM
James92's Avatar
James92
I'm going to lower mine this weekend as well, will the car need an alignment afterwards?
Old Feb 19, 2009 | 10:14 PM
matt75's Avatar
matt75
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
http://www.corvetteforum.cc/techtips...D=90&TopicID=1
i lowered on stock bolts, then didn't think it was low enough. takes a little time the first time. if you make several adjustments like i did over the course of a couple of months you'll be able to do the whole thing very quickly.
Old Feb 19, 2009 | 11:41 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Nice ride! Did you cut the bushings? Are those stock size wheels?
I swung by me mechanic after work today. He put the car on a lift and tightened all the bolts in no more than 10 minutes. Didn't need to remove the front wheels. Car looks much better!
Old Feb 20, 2009 | 09:54 AM
matt75's Avatar
matt75
Thanks! I purchased a lowering kit which replaces all the bolts and bushings. Car came down a little more than it was originally with tightened stock bolts. The kits run about 35-50 bucks depending on where you purchase from.
Yes, stock wheels on her
Old Feb 20, 2009 | 10:08 AM
sammm's Avatar
sammm
Yes it will. Let it settle for a few weeks or so before you get it re-aligned.
Old Feb 20, 2009 | 01:02 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Where did you buy the lowering kit?
Old May 5, 2009 | 11:38 AM
TC101's Avatar
TC101
Can someone explain to me how to just REMOVE the front bolts? I have the rear adjustables installed but my front is lowered on the stock bolts all the way but it still has a lot gap in there. I have a pair of front lowering bolts (well not really bolts) but should I just take them out instead? Im confused how you can just remove them and everything be OK.
To Need quick answer about lowering on stock bolts
