funny knocking sound
Old Feb 19, 2009 | 04:14 PM
KWIKSILVERZ's Avatar
KWIKSILVERZ
Default funny knocking sound
I've noticed that after cranking the car and it idles I'm hearing a rattle or knocking sound that seems to be coming from under the car. It does not sound like an engine knock, but more like a dull metal thud...I figure it may be the exhaust pipe tapping against another fixed object?
In neutral (or in gear with clutch in) I've hit the throttle to see if the noise stops or increases/decreases with RPMs. It doesn't seem to do either, although it is not heard under throttle...it's probably there, but the engine noise drowns it out. This sound remains even after short trips, longer trips, and casual driving or spirited driving. It's noticeable in the car as well as outside the car.
Anyway, I do not have access to a lift or ramps so I can't crawl underneath to see what the source is. Anyone else experience this? It's a 2003 Z with 17,500 miles, and is completely stock. It's a relatively new discovery so I'm guessing something has worked itself loose?
Old Feb 20, 2009 | 02:36 AM
KWIKSILVERZ
anyone?
Old Feb 20, 2009 | 03:33 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Sounds like you are going to HAVE to get underneath it to hear where it is coming from.
You can get a floor jack and two floor stand set for well under fifty bucks. Even if you only get it up far enough for what I propose.
Cut up an old garden hose so you have about a three or more foot length. Hold one end to your ear and use the other end to wander around underneath until you hear the knock. It's an old-school technique that works for all kinds of trouble-shooting. It'll tell you exactly where the knock is coming from.
Old Feb 20, 2009 | 12:29 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree too. You really need to get under there. Buy a set of ramps or take it to someone with a lift that you can park it on briefly to get a listen under there.
Old Feb 20, 2009 | 01:00 PM
Jet-Jock's Avatar
Jet-Jock
Is the engine cold when it happens and then the noise dissipates when it comes up to operating temp?
Old Feb 20, 2009 | 03:37 PM
KWIKSILVERZ
I'd like to say yes, but no. The most recent trip I took in the car was just 12 miles, but it's a 30+ minute drive due to traffic. It was the same as when it was started. It's far more noticeable while the car is in the garage due to the tight space. Very frustrating that I'm not able to get under there any time soon.... The hose idea is my next best bet until I get some time. Keep the suggestions coming, please!
Old Feb 20, 2009 | 09:17 PM
KWIKSILVERZ
Default update...
I cranked her up again this afternoon to give it a closer listen. While sitting in the car with door open and car out of gear, I gave progressive application to gas pedal while I held my head outside of car cabin. It DOES seem that the rattle increases speed with throttle application, but is faint and harder to hear with engine noise. Someone suggested the torgue tube may be going...not sure. Haven't noticed any performance problems so can't shed much more light than this...
Old Feb 20, 2009 | 09:34 PM
Navyvette04's Avatar
Navyvette04
Is you car a 6 speed? If so, Does the noise go away with the clutch depressed?
Old Feb 20, 2009 | 09:53 PM
Jet-Jock's Avatar
Jet-Jock
What he said, was the clutch in or out, when you accelerated the engine?
Old Feb 20, 2009 | 11:43 PM
randy814u's Avatar
randy814u
Its a long shot but my 98 did pretty much the same thing.
It turned out my one of my cats fell apart inside, and was rattling around. It sure sounded like the engine or clutch setup was doing it. I found it by getting the car in the air to listen to it. Then tapped on the exhaust with a rubber hammer. I was relieved to say the least.
Good luck with it, Randy
Old Feb 21, 2009 | 12:13 AM
Mixxit's Avatar
Mixxit
Bearings in your idler pulley. If that's it, it's a pretty easy fix. There should be many posts on it. Give it a search and see if that's the problem. Good luck.
Old Feb 21, 2009 | 01:36 AM
Oh 2 Fun's Avatar
Oh 2 Fun
I'm still tellin' ya...the hose trick will pinpoint where the noise is. It works.
Old Feb 21, 2009 | 06:49 AM
KWIKSILVERZ
I *believe* both. I'll have to check again to be sure...
-----yes its a 6 speed and no, the noise remains...
------Honestly, this is my suspicion.
-------I will definitely look into it
--------LOL! I'm on it when I get home.... Thanks all for the leads/suggestions.
Old Feb 21, 2009 | 07:09 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Is this the old "as soon as I crank my car up and start to drive it down the road I hear a clicking or knocking sound in the motor and as I drive it it goes away"?
I don't think this is what you are talking about but mine does this. It seems that many LS1's do it, and maybe some of the LS6's too. I crank my car up every morning and it sounds pretty rough. I back it out of the driveway, put it in first gear, and by the time I wind up 1st gear and shift to second the noise is gone. Usually takes about 100 ft until the noise disapears.
Weird, and doesn't sound right at all, but alot of people seem to have this issue.
Old Feb 21, 2009 | 07:20 AM
KWIKSILVERZ
nope...not the same. based on the searches I've done so far it's leaning toward a broken weld in the exhaust or a cat going bad. won't know until I get her up in the air, tho.....
Old Feb 21, 2009 | 07:21 AM
KWIKSILVERZ
Old Feb 21, 2009 | 10:50 AM
Clint43's Avatar
Clint43
i know this may sound crazy but look at the clamps that hold your air filter in. i notice when i started my car the other day that there was a knocking or rattle of some sort anyway i open the hood sure enough both clamps that hold the airfilter on came lose. i still have no idea how they came lose because they are on there pretty good.
To funny knocking sound
Old Feb 21, 2009 | 11:17 AM
KWIKSILVERZ
...okay. After aout 30 minutes of trying to crawl under this car I was able to accomplish the following: I believe now more than before that my problem is a failing cat. Under acceleration it becomes harder to hear, but when the rpm's drop it becomes more noticeable. The sound seems to be strongest around the cats and it is like hearing a small piece of metal flopping around inside. I shook the crap outta the pipes to check for weld breaks/loose connections...no luck. The rattle/knocking sound is almost consistent under accel/decel, but a little delayed. If this is the cat, isn't the GM emmission warranty good for 7 years? If so, this could be a dealership fix I'd think?
Oh, and the hose trick worked enough to get me to the cats and away from the tranny
Old Feb 21, 2009 | 12:18 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I would agree that the cats are a likely suspect.
Emissions components have a longer warranty (I don't remember the time) but you could call the stealer to ask or I'm sure someone on here knows as well.
Old Feb 22, 2009 | 04:14 AM
KWIKSILVERZ
I'll look in my car paperwork. Even though I'm the 2nd owner, I should still be covered if time hasn't lapsed. I'm thinking it's 7 years though...
