funny knocking sound
Old Feb 22, 2009 | 12:59 PM
TXCyberSport's Avatar
TXCyberSport
I just recently had a pop corn sounding noise comming from underneath and could not find the source. It would do it on cold mornings usually and after a short drive would go away. Finally the starter started to fail and would not fully disengage. I replaced the starter and the noise is not there anymore. Just another suggestion.
Old Feb 22, 2009 | 01:30 PM
robbyd831's Avatar
robbyd831
i think i have a simliar prob. ive been noticing some noise from under the car as well. i dont nkow what it is. i think im gunna take it 2 the dealership'
Old Feb 22, 2009 | 02:48 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Originally Posted by Dark Knight Z06
Oh, and the hose trick worked enough to get me to the cats and away from the tranny
Cool....
Old Feb 23, 2009 | 04:45 AM
KWIKSILVERZ's Avatar
KWIKSILVERZ
Much obliged for the input. If for some reason the cat(s) aren't the cause, I'll look into it
Old Feb 23, 2009 | 04:50 AM
KWIKSILVERZ
Does it kinda resemble a marble bouncing and rolling around in a can? Is it sounding louder towards the front of the car and underneath? If so, then it is probably the same thing I'm dealing with. I'm getting mine in this week. I discovered the cats are covered for 8 years
Old Feb 23, 2009 | 05:39 AM
DAN01's Avatar
DAN01
This maybe the same problem I just had but not with my vette. I have a '92 caddy Allante and I thought the exhaust pipes brackets were loose and I tightened them up but the noise was still there. Found out that it was the cat converter. Replaced it and no more noise.
Old Feb 27, 2009 | 12:50 AM
KWIKSILVERZ
Default noise confirmed...
To close on this, I took the Z to the dealership today to confirm my belief that the Cat(s) were failing. As I pulled in to the service entrance my check engine light came on and the DIC threw code P0430 which would later translate to the #2 Bank (right side) catalytic converter not operating efficiently. The cat is covered by the GM Emission warranty for 8 years/80,000 miles for those who wanted to know and will be covered! Anyway, prior to taking the car in I noted that there was an ash-gray colored soot built up in the exhaust tips on the right side. Just another indicator. Thanks all to who offered suggestions. It was/is very much appreciated!
Old Mar 4, 2009 | 01:26 PM
robsc501's Avatar
robsc501
Hi KWIKSILVERZ:
I was wondering what the mileage is on your z when the right cat went out? Did the dealer recommend to be replaced in pairs meaning changing the left & the right sides at the same time? Good for you that the warranty covered that item. Stuff usually happens after the warranty expries.
robsc501
Old Mar 5, 2009 | 07:07 AM
KWIKSILVERZ
It had around 17,400 on the clock when I first "heard" the noise, but it escalated rather fast from there. I put it the shop with 17640 on the clock. As for the replacement, no. The dealer would not change both...just the problematic one. I'm not always quick to bash dealerships, but in this case it may make them money down the road if the other cat were to go after the 8 year warranty expires. In my case I still have a few years of coverage since the original owner bought it in 2004.
