Need help
Old Mar 5, 2009 | 12:46 AM
T-TOP TOM's Avatar
T-TOP TOM
Default Need help
I lost my only key to my 2001 vette, can a regular locksmith make a key from the vin. # or do I have to go back to the STEALERSHIP? Thanks for any info.
Old Mar 5, 2009 | 01:06 AM
2000lambovette's Avatar
2000lambovette
If it had the computer chip in it you will need a dealer. I believe all had chips but dont know for sure.
Old Mar 5, 2009 | 02:00 AM
dougbfresh's Avatar
dougbfresh
It's only a resistor pellet in the key, the dealer will make one from the VIN but it WILL COST $$$$.
Old Mar 5, 2009 | 02:25 AM
DeeGee's Avatar
DeeGee
You need a key cut which has a correct resistor pellet fitted. Either measure the resistance on your current key and then get one cut with the right setting. Maybe easier (but more $$) to go to a dealer and have him get the correct key for you.
Here are the values if you go DIY
VATS key codes:
The BCM measures the resistance value of the resistance of the pellet and allows the fuel system to operate. If it is within +/-10% the car will start.
To check your key value:
Set your digital volt meter to “ohms mode” and measure the value across the pellet.
The 15 resistor codes are:
Resistance Value (Ohms)
1 0.402 (acceptable range .386-.438)
2 0.523 (acceptable range .502-.564)
3 0.681 (acceptable range .650-.728)
4 0.887 (acceptable range .850-.942)
5 1.130 (acceptable range 1.085-1.195)
6 1.470 (acceptable range 1.411-1.549)
7 1.870 (acceptable range 1.795-1.965)
8 2.370 (acceptable range 2.275-2.485)
9 3.010 (acceptable range 2.890-3.150)
10 3.740 (acceptable range 3.590-3.910)
11 4.750 (acceptable range 4.560-4.960)
12 6.040 (acceptable range 5.798-6.302)
13 7.500 (acceptable range 7.200-7.820)
14 9.530 (acceptable range 9.149-9.931)
15 11.801 (acceptable range 11.320-12.290)
Old Mar 5, 2009 | 04:22 AM
KWIKSILVERZ's Avatar
KWIKSILVERZ
I got the dealership to run my vin and tell me what the vats code was. I then found a few places on-line that sell key blanks for about $12-$15. I had my key cut at a local hardware store and have used it ever since with no problems. Dealership didn't charge me anything to get the code.
Old Mar 5, 2009 | 07:52 AM
Once you have the VATS code, a locksmith should be able to make a key for you.
To Need help
