[Z06] Odd knocking noise down below....
Old Feb 20, 2009 | 03:43 AM
KWIKSILVERZ's Avatar
KWIKSILVERZ
Default Odd knocking noise down below....
Alright get your minds outta the gutter
I'm hearing at idle whether in gear or out of gear, what sounds like a dull metallic clanking/knocking/rattling sound. It seems to originate from under the car and I can't localize it to the front, rear, or somewhere in the middle. First guess without being able to see it is possibly the exhaust pipe tapping against something?
No ramps or lift access so I can't crawl underneath to see for myself. Wondered if anyone in Z06-land has any ideas. The car is all stock and has 17k miles (2003Z), I posted in general section too, but got no love, there... This sound is driving me nuts since it can be heard inside and out......
Old Feb 20, 2009 | 04:12 AM
slothy's Avatar
slothy
does it go away when you push in the clutch?
Old Feb 20, 2009 | 07:16 AM
KWIKSILVERZ
nope. it's still there with the clutch pushed in or with the car out of gear and the clutch is out. If it helps, the odd sound is not consistent with acceleration/RPM changes either. Just harder to hear when revved due to engine sound. it "kinda" resembles the sound you hear when a car diesel's but its not quite the same. Doesn't seem to be coming from the motor, but somewhere behind the motor and underneath the car.
Old Feb 20, 2009 | 08:20 AM
Z06_BluByU's Avatar
Z06_BluByU
if the car wasnt properly warmed up this was probably just piston slap..
Old Feb 20, 2009 | 09:25 AM
AlwaysInBoost's Avatar
AlwaysInBoost
if the knocking increased with the RPM I would say thats a very bad sign, probably a spun bearing... hopefully thats not it.
can you hear it both inside and outside the car?
Old Feb 20, 2009 | 03:30 PM
KWIKSILVERZ
The noise is noticeable inside and outside. As for the piston slap, the noise remains after lengthy trips of say 50+ miles.
Old Feb 20, 2009 | 04:31 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Probably just gear rattle. Mine does this also.
Put the car in neutral, take your foot off the clutch and then turn the key off. Is that the sound your hearing? if so, its gear rattle. and its normal on a Z06.
Old Feb 20, 2009 | 09:27 PM
KWIKSILVERZ
will give that a try when I get home. My 02 Z didn't do this, but it had just 8,000 miles on it before being totaled.... Will update after checking!
Old Feb 20, 2009 | 09:51 PM
Steve20's Avatar
Steve20
just curious, what do you think would cause the noise, if it went away with the clutch pedal depressed??
Steve
Old Feb 21, 2009 | 11:38 AM
KWIKSILVERZ
Nope that's a different sound altogether. I am almost certain it's a failing cat. I crawled under the car...well kinda just did some reachin' and tappin' around and it's almost definitely in the pipes. I used a piece of garden hose to listen for sounds...and it actually workd well enough to get me in the area of the cats and away from the tranny. If GM's emission warranty is good for 7 years, I think it's a possibilty I can
get it fixed on them.
Old Feb 21, 2009 | 02:07 PM
Black04Z06's Avatar
Black04Z06
This sounds like a warranty claim I had 2.5 years ago. It was a cat in my case. The noise was a marble in a can sound.
Old Feb 21, 2009 | 10:01 PM
Stevo92z28's Avatar
Stevo92z28
Steve
Nevermind.
Old Feb 22, 2009 | 02:52 AM
KWIKSILVERZ
that's a decent description of my noise. It sounds like GM covered ya
Old Feb 27, 2009 | 12:38 AM
KWIKSILVERZ
Default noise confirmed...
To close on this, I took the Z to the dealership to confirm my belief that the Cat(s) were failing. As I pulled in to the service entrance my check engine light came on and the DIC threw code P0430 which would later translate to the #2 Bank (right side) catalytic converter not operating efficiently. The cat is covered by the GM Emission warranty for 8 years/80,000 miles for those who wanted to know and will be covered! Anyway, prior to taking the car in I noted that there was an ash-gray colored soot built up in the exhaust tips on the right side. Just another indicator. Thanks all to who offered suggestions. It was/is very much appreciated!
Old Feb 27, 2009 | 09:10 AM
bmg's Avatar
bmg
Thanks for the follow up!
To Odd knocking noise down below....
