battery dead...again?
Old Feb 22, 2009 | 05:35 PM
KWIKSILVERZ's Avatar
KWIKSILVERZ
Default battery dead...again?
Ok, I don't know what's going on here, but after changing the battery out for a new one only 1 week ago, my new one is dead! Nothing was left on and the last time I was in the car was yesterday while listening for the funny knocking sound (that I believe is 1 of the cats failing ). The car was running for about 30 mins and wasn't driven after. Could tht have been enough to drain a brand new battery so fast??? Also, the temps dropped a bit low the past two nights (upper 40's in FLA overnight). I know temps have an impact on battery wear...but GEEZ!
Anyway, my wife is talking about buying me a battery tender for a B-day gift now...sounds like it might be a good idea since the car is rarely driven! Any other input would be great...can't believe it died so fast! Any suggestions on a battery tender would be cool, too. Thanks!
Old Feb 22, 2009 | 05:58 PM
What you mention should not have drained the new battery that fast. I'd say you have a problem somewhere in the electrical system - some short somewhere that is keeping a constant drain on the battery. Might want to have someone take a look at the car.
Old Feb 22, 2009 | 06:10 PM
Hammer99's Avatar
Hammer99
You didn't drive it at all but just ran it for 30min. in driveway? Thats all you did w/ new battery installed? Just a guess, you may have an issue w/ the alternator. My car has no probs sitting 2 weeks. I use Battery Tender Plus if I plan to leave it more than 2 weeks. Picked it up on Amazon.com for 43.00 no shipping (on sale last year). Good luck!
Old Feb 22, 2009 | 06:26 PM
Tim01Coupe's Avatar
Tim01Coupe
Power seats have been a culprit here on many posts.
Old Feb 22, 2009 | 06:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Park the car in a dark garage or wait until after sundown - you sure there isn't a light left on? Check things like the courtesy lights on the mirror and the glove box.
Old Feb 22, 2009 | 07:25 PM
dobewillie's Avatar
dobewillie
you sure have a problem good luck with a quick inexpensive fix also get a battery tender 15 buck at walmart
Old Feb 22, 2009 | 09:44 PM
THE TECH's Avatar
THE TECH
Any aftermarket electronic devices installed or items plugged into the cigarette lighter??
Old Feb 22, 2009 | 10:50 PM
ValiantSailor's Avatar
ValiantSailor
Is your alternator charging?
Old Feb 23, 2009 | 01:06 AM
KWIKSILVERZ
found the culprit....
My 17.5 year old teenage son
He was "sitting in the car" after I went to bed (I work nights and sleep during the day) and was playing with the "buttons" in the car. He must've turned the interior lights on and forgot to turn the switch off
After a quick jump start, all seems good. For fun, I even tried to jump the original battery and, go figure, it holds a charge just fine...Junior just paid me $90 for a new battery
Old Feb 23, 2009 | 01:08 AM
KWIKSILVERZ
Just curious...how are they problematic?
BTW, thanks all for the help
Old Feb 23, 2009 | 10:14 AM
tricep's Avatar
tricep
St. Jude Donor '09
I have had the battery drain over the rearview courtesy light.
I have also experienced the loose battery cable with the hole not tapped deep enough.
I have dropped bolts and wrenches down under the battery plate and I have had to remove it completely. Now I know to throw a rag down before working on the battery posts, terminals, etc.
There are four big bolts that hold the plate down under the battery on a Z...
I haven't figured out exactly why that is... maybe if you flip the car over it insures the battery stays in place?
Old Feb 23, 2009 | 11:57 AM
TEXHAWK0's Avatar
TEXHAWK0
Sounds like junior may not make it to 17.6 years.
Since he now is the proud owner of a battery, does he have a car to go with it?
Old Feb 23, 2009 | 01:05 PM
justin_heat05's Avatar
justin_heat05
my battery kept running down as well, ended up being the light bulb in the glove box. The door wasn't touching the button that turns the light off and you can't tell if its on with the door shut. I just took the bulb out and no more dead battery.
Old Feb 23, 2009 | 01:14 PM
Jim2003's Avatar
Jim2003
Got a question. I have a 03 vette I am the only owner. I believe that when I read the owners manual in 03 I thought I read that if you leave a light on, the computer cuts it off in 15 or 20 minutes. I do know that when I work on the car such as oil change or detail the interior my under the hood light and my interior lights go off.
So if the computer turns off the lights, how can a light be left on and run down the battery? I just don't think that is possible with the vette.
Old Feb 23, 2009 | 01:38 PM
tricep's Avatar
tricep
St. Jude Donor '09
it was possible with my 2000... I had my car detailed and the dimmer switch was clicked "on" - I couldnt see it in the daylight and didnt know enuff about Vettes at the time.
I was told by a Chevy mechanic to check it- sure enuff-
Now, whether it clicked off and had pulled enough juice to cause a problem, I don'ts knowz
Old Feb 23, 2009 | 04:02 PM
KWIKSILVERZ
...well, I HAVE flipped my Vette before and YES, it did stay in place Too bad it cost me a car
Old Feb 23, 2009 | 04:05 PM
KWIKSILVERZ
The rate he's goin, he'll be a proud owner of my pile of cardboard boxes...he thinks they're for packing his stuff when he eventually moves out. What he has since been told is that he won't be taking anything with him and he'll be LIVING in those boxes. He can use the battery to power his flashlight or something
Old Feb 23, 2009 | 04:12 PM
KWIKSILVERZ
Didn't think so, either. I waited until it was dark in the garage to check for light seepage and found all to be dark. I then began to check switches and discovered that the interior light switch was left on. Considering that was the only thing out of the ordinary, it had to be the issue. My son told me he had been playing in the car without starting it so that, coupled with my 1/2 hour noise search and no drive, the battery was toast.
Old Feb 23, 2009 | 04:17 PM
Dale96's Avatar
Dale96
I think junior getting to buy a brand new battery was a lesson well deserved-hopefully well learned!!!
To battery dead...again?
