[Z06] Fluids Fluids Fluids
Old Feb 27, 2009 | 12:43 AM
Dans-Z06's Avatar
Dans-Z06
Default Fluids Fluids Fluids
My car is getting old. So i'll be doing a full fluid change this upcomming oil change.
What do you guys like?
Coolant - Prestone 50/50
Transmission - Royal Purple Max ATF
Differential - Royal Pural Synthehic Gear Oil
Engine Oil - Mobile
Filter - Mobile
Hydrolic Clutch Fluid - Prestone DOT 3
Then to add to the mix
4 BFGoodrich g-Force Sport
YAY or NAY? On my choices?
If theres something better i should be getting, a couple pennies is nothing. Breakfluid will be done when breaks will be dieing but so far so good. Any fluid i missed?
Old Feb 27, 2009 | 02:35 AM
Last C5's Avatar
Last C5
I think I'd use a DOT 4 like ATE Type 200 for the clutch and the brakes. And, since you're in a fluid changing mood, why not change out the power steering fluid too?
Old Feb 27, 2009 | 08:44 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Do I understand correctly that brake fluid and hydraulic clutch fluid are not exactly the same thing???
Old Feb 27, 2009 | 09:05 AM
KCvetteowner's Avatar
KCvetteowner
Actually you do use the same fluid for both. I use Valvoline Synthetic Dot3/4.
Old Feb 27, 2009 | 09:22 AM
kerryt1's Avatar
kerryt1
Comments in blue italics
Coolant - Prestone 50/50 + Watter Wetter
Transmission - Royal Purple Max ATF I've heard from a national builder that this eats carbon components, so I went with Mobil ATF
Differential - Royal Pural Synthehic Gear Oil I run RP 75W-90 I think
Engine Oil - Mobile Mobile 5W-30, RP, Amsoil, or Redline
Filter - Mobile AC Delco, Wix, Napa Gold, Mobile
Hydraulic Clutch Fluid - Prestone DOT 3 same + Ranger method
Old Feb 27, 2009 | 09:39 AM
VetteHunting's Avatar
VetteHunting
Amsoil.
Old Feb 27, 2009 | 12:22 PM
TEXHAWK0's Avatar
TEXHAWK0
Engine Oil - Mobile I guess all oil is mobile, but Mobil 1 is good. There are plenty of other oils, including Valvoline synthetic, that now meet the Corvette spec. and claim to actually reduce wear more than Mobil 1.
Filter - Mobile I used to use AC Delco, but now I use WIX in all my cars.
Hydrolic Clutch Fluid - Prestone DOT 3 I use the GM clutch fluid since the reservoir only holds a couple of ounces.
Even if you do not flush the brake system, I would go ahead and change the fluid in the reservoir. I just use the Prestone DOT 3 fluid from Walmart.
Old Feb 27, 2009 | 12:31 PM
TEXHAWK0's Avatar
TEXHAWK0
The GM clutch fluid is supposed to have additional friction reducing additives, but you can just use brake fluid. I use the GM fluid since the reservoir only holds about 2 ounces.
Some guy recently posted that he changed the power steering fluid in his reservoir and it the power steering quit working. I still cannot imagine what he could have done to cause that. At first he thought that the wrong P/S fluid was used, but I don't think Corvettes use anything special.
Old Feb 27, 2009 | 12:50 PM
Steve20's Avatar
Steve20
P/S is synthetic on the C4's so I would think they would still require syn on C5's
Engine Oil= any synthetic meeting the GM 4718M specificiation is fine. The last oil I would use is Mobil-1-it has been producing high iron (wear) numbers in used oil analysis
Steve
Old Feb 27, 2009 | 04:42 PM
Dans-Z06's Avatar
Dans-Z06
that's a lot of great info, but about your motor oils.
They are not on the GM High Performance Approved Engine Oil List
http://www.gm.com/corporate/responsi...ngine_oils.pdf
So changing my list
Coolant - Prestone+Water 50/50 mix
Transmission - ?? IDK
Differential - Royal Pural Synthetic Gear Oil
Engine Oil - Castrol SLX Professional
Filter - Mobile or AC Delco?
Hydrolic Clutch Fluid - Prestone DOT 4
Is everything good? Meets specifications?
Old Feb 27, 2009 | 05:21 PM
VetteHunting
Transmission - Amsoil ATF
Differential - Amsoil Severe Gear
Engine Oil - Amsoil Signature Series
Filter - Napa Wix
Old Feb 27, 2009 | 05:28 PM
Bill Dearborn's Avatar
Bill Dearborn
So changing my list
I assume you are using Prestone's version of DexCool. However, use the non mixed antifreeze and mix it yourself. When you drain the old coolant there will always be several quarts remaining in the engine block. I usually drain/refill/drain several times with clear drinking water (GM recommendation) from the hose until the drained fluid runs clear. Then I add the appropriate amount of antifreeze to get the 50/50 mix. If you add a 50/50 mix to the clear water that is in the block you end up with ~ 60+/40- mix of water to antifreeze. That changes your boiling and freezing points. If you want to use the water wetter and can stand a higher freezing point then increase the percentage of water to antifreeze to something like 75/25 as water wetter works better with lower concentrations of antifreeze. It works best with straight water. At the 50/50 mixture level water wetter has a barely noticeable affect.
Bill
Old Feb 28, 2009 | 01:36 AM
sami85L98's Avatar
sami85L98
Get the AMSoil ATD (which is newer than ATF) for transmission, i use Amsoil iATF n M12 tranny and ATD was no available at that time.
Good point by Bill for coolant.
To Fluids Fluids Fluids
