[Z06] '03 ZO6 brake problem
Old Feb 28, 2009 | 09:48 PM
erics1's Avatar
erics1
Default '03 ZO6 brake problem
My right rear axle has been rubbing against my hard line brake tube. You guessed it 75 mph and no brakes I have 16000 miles on the car and a hole in my brake line. Does any one know of a place to get it? pre bent, dealership? may be something to check out on your cars. any help would be really cool
Eric
Old Feb 28, 2009 | 09:52 PM
vsocks1's Avatar
vsocks1
I didn't think you would lose all brakes they way they are piped...
Old Mar 1, 2009 | 11:55 AM
Z06_BluByU's Avatar
Z06_BluByU
Eric
I think the only place to get one pre-bent is if you take it off another C5.. try corvette salvage yard
Old Mar 1, 2009 | 01:05 PM
slong's Avatar
slong
Glad you made a safe stop and good advice on checking our own set-ups. Just curious, have you approached the manufacture with this issue?
Old Mar 5, 2009 | 08:17 PM
erics1's Avatar
erics1
No I have not and you do lose all bakes pedal right to the floor
erics1's Avatar
erics1
pedal to the floor
Old Mar 5, 2009 | 09:31 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Are you running stock wheel and tire size? That seems kind of weird to be happening. Something must be amiss somewhere for the tire to rub a hole in the brake line.
Old Mar 5, 2009 | 10:49 PM
ZR1991's Avatar
ZR1991
You should not have lost all pressure. but that is another issue. The prebent tube should be easily available from the dealer.
But you need to find out about that loss of pressure. That just almost can't happen in today's designs. You should have it carefully checked.
Regards,
Old Mar 6, 2009 | 02:44 PM
2A372C's Avatar
2A372C
Yeah that happened to me as well on the drivers side. I also slowly lost all my brakes but I had just enough to turn around and go home. If I had been on the track I would have been in trouble.
I noticed that at high speed my cv shaft boots actually grow just like a drag tire and when they do they can grab anything thats in that area.
When you order the brake line GM part #(12547207 3/16 brake line) it comes in as a roll of tubing with no ends so you will need to reuse the ends and use a flare tool to open up the ends. And you also will have to bend them yourself.
Yeah I also thought this was BS but what can you do.
Old Mar 6, 2009 | 02:50 PM
z06 hellcat's Avatar
z06 hellcat
many auto part's store's will make one up for you, they are very cheap or you can try your local hose company
Old Mar 10, 2009 | 09:03 PM
2A372C's Avatar
2A372C
Oh also the ends are not the common flare type like I was use to they are a little different. The factory flared them out and then back in. Looks like a little shower head with one hole in it.
Old Mar 10, 2009 | 10:29 PM
TEXHAWK0's Avatar
TEXHAWK0
All brake lines are double flared so you need special dies to make them up, but they are common. Any good garage should be able to fix that for you.
To '03 ZO6 brake problem
