need a gm part #
Mar 2, 2009 | 02:20 PM
need a gm part #
can't seem to find the gm part number for a clutch master cylinder for a 04 Z06. if someone could give me that i would appreciate it.
Mar 2, 2009 | 02:45 PM
The number I get up here in Canada for it is 12564455. My catalog shows both the Z06 and the regular M6 C5s taking the same one.
Mar 2, 2009 | 02:51 PM
I should also add the all manuals take that very same master - 1997-2004.
Quote:
Originally Posted by
Rob01C5
hmm that shows up right but i remember seeing them for $70 but i can't remember the number.
Mar 2, 2009 | 03:21 PM
JoeAZHP
If you can still get them for $70 I'll buy a box of 10.
Mar 2, 2009 | 03:54 PM
Rob01C5
Mar 2, 2009 | 05:08 PM
If there is doubt, try Gene Gulley here on the forum, and he should be the best price as well.
Mar 2, 2009 | 06:42 PM
Mar 2, 2009 | 06:48 PM
Rob01C5
For some reason, these catalogs show a part number for the slave cylinder, but not the master cylinder.
Mar 2, 2009 | 07:05 PM
Hi There:
The GM p/n is 12564455 sells for $ 130.33. Found on
www.gmpartshouse.com www.rockauto.com says dormain p/n CM 350108 is the same as 12564455 sells for $35.79. Judging from prior experience I would buy the gm item for $130.33.Try Gene Culley who is one of our venders on this forum.
robsc501
Mar 2, 2009 | 07:14 PM
give Gene a call
Mar 2, 2009 | 07:24 PM
i know of gene but when you go to his site and click on master cylinder it goes to a blank page. therefore needed a part number for it.
Mar 6, 2009 | 09:55 PM
Premium Supporting Vendor
Thanks for the referrals all!
Here is the list!
||--Genuine GM C6 Z06 LS7 Clutch Kit--||
24248985 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are 441.42 total.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
89059282 - LS6 Slave Cylinder – 127.79
12564455 - LS6 Master Cylinder – 130.33
14061685 – Pilot Bearing – 12.41
*Clutch does work in any LS1/LS6 drive train but must also have ls7 flywheel.
Also, can only use LS1/LS6 hydraulics.
