I am looking to get a set of wheels but think they might stick out quite a bit, does anyone know if a set of C6 Z06 Replicas 5x4.75 bolt pattern - 19x9.5 front -20x11 rears with offsets +57 front and +79 rear work on my stock 2002 Z? I think the fronts should be fine but worried about the rears. The tires on them are 275-30-19 NANKANG NS-11's on the front and the rear tires are 295 30 20 Toyo Proxes 4 295/30R20 Performance Tire's. Thanks!
The rear wheels need a 62-65mm offset. Those 79mm offset wheels are for a C6 & will rub on the inner fenders. The front wheels have the correct offset.
